Hi List,
when installing geoserver-2.3-beta1-wps-plugin into geoserver version 2.3-beta mosaic and pyramid layers stop to show up in my installation. I’m using geoserver.war under tomcat6.
Below is info ‘About Geoserver’ and error log rows from ‘catalina.out’.
Geoserver is now working without wps plugin, but I am willing to have that as well. Tested few earlier versions with same results. Is there any trick to get this working?
with greetings,
Heikki
Build Information (About geoserver tab)
Version 2.3-beta1
Git Revision 0db19e78dd691cecc1d6d6d37c3ec983c8edea11
Build Date 24-Jan-2013 09:32
GeoTools Version 9.0-beta1 (rev e4710e958dbd3bca4ea4d9a500dcdd5f12bd2144)
GeoWebCache Version 1.4-SNAPSHOT (rev 3279da2256f5acb0287d26b0543040bbf908f601/3279da2256f5acb0287d26b0543040bbf908f601)
Server status
Data directory /home/geoserver/data
Locks 0
Free locks
Connections 4
Memory Usage 127 MB
Free memory
JVM Version Sun Microsystems Inc.: 1.6.0_38 (Java HotSpot™ 64-Bit Server VM)
Available Fonts GeoServer can access 236 different fonts. Full list of available fonts
Native JAI true
Native JAI ImageIO true
JAI Maximum Memory 910 MB
JAI Memory Usage 768 KB
Free memory
JAI Memory Threshold 75.0
Number of JAI Tile Threads 7
JAI Tile Thread Priority 5
ThreadPoolExecutor Core Pool Size 5
ThreadPoolExecutor Max Pool Size 10
ThreadPoolExecutor Keep Alive Time (ms) 30000
Update Sequence 230
Resource Cache
ERRORS FROM LOGFILE catalina.out
AFTER INSTALLING geoserver-2.3-beta1-wps-plugin
02 Feb 14:54:38 INFO [geoserver.wms] -
Request: getServiceInfo
Error: One factory fails for the operation “Mosaic”
Occurs in: org.geoserver.jai.ConcurrentOperationRegistry
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor233.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
at org.geoserver.jai.ConcurrentOperationRegistry.invokeFactory(ConcurrentOperationRegistry.java:412)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getSampleModel(RenderedOp.java:2233)
at org.geotools.resources.image.ImageUtilities.maskColor(ImageUtilities.java:906)
at org.geotools.gce.imagemosaic.RasterLayerResponse.postProcessRaster(RasterLayerResponse.java:710)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:698)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:652)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:340)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:994)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutputFormat.java:1296)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:861)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:333)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:255)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:127)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:466)
at org.geoserver.wms.GetMap.run(GetMap.java:201)
at org.geoserver.wms.GetMap.run(GetMap.java:111)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:356)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:69)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:50)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy28.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:46)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:103)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:877)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:594)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1675)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: coordtype - Could not find the key.
at com.sun.media.jai.util.CaselessStringArrayTable.indexOf(CaselessStringArrayTable.java:88)
at com.sun.media.jai.util.CaselessStringArrayTable.indexOf(CaselessStringArrayTable.java:102)
at javax.media.jai.ParameterBlockJAI.indexOfParam(ParameterBlockJAI.java:273)
at javax.media.jai.ParameterBlockJAI.checkParameter(ParameterBlockJAI.java:732)
at javax.media.jai.ParameterBlockJAI.setParameter0(ParameterBlockJAI.java:793)
at javax.media.jai.ParameterBlockJAI.setParameter(ParameterBlockJAI.java:712)
at org.jaitools.imageutils.ROIGeometry.getAsImage(ROIGeometry.java:477)
at com.sun.media.jai.opimage.MosaicOpImage.(MosaicOpImage.java:374)
at com.sun.media.jai.opimage.MosaicRIF.create(MosaicRIF.java:39)
… 122 more
02 Feb 14:54:39 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:335)
Caused by: org.geoserver.platform.ServiceException: javax.media.jai.util.ImagingException: All factories fail for the operation “Mosaic”
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:898)
… 103 more
Caused by: javax.media.jai.util.ImagingException: All factories fail for the operation “Mosaic”
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1687)
… 104 more
Caused by: java.lang.reflect.InvocationTargetException
… 117 more
at com.sun.media.jai.mlib.MlibMosaicOpImage.(MlibMosaicOpImage.java:49)
at com.sun.media.jai.mlib.MlibMosaicRIF.create(MlibMosaicRIF.java:74)
… 122 more
