[Geoserver-users] Mounting your block at the root level
In documentation i can read :
You can mount your block at the root level in the application URI space, so that instead of using (for example) the URI http://localhost:8888/myBlock/foo/bar to request a page, you would request it at http://localhost:8888/foo/bar.
To do this, edit myBlock/src/main/resources/META-INF/cocoon/spring/block.xml , and change the element
    <property name="mountPath" value="/myBlock1"/>
to
    <property name="mountPath" value=""/>
is it still working ?
When i create the lock , there is no block.xml file. and when i create one , i got an exception...
2008-01-21 16:03:26.018::WARN: Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/,/home/geindre/workspace2/flysafeWebApp/target/flysafeWebApp-1.0-SNAPSHOT}
org.springframework.beans.factory.BeanDefinitionStoreException: Unable to read spring configurations from classpath*:META-INF/cocoon/spring; nested exception is org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 2 in XML document from URL [jar:file:/home/geindre/.m2/repository/fr/meteo/advanced/1.0-SNAPSHOT/advanced-1.0-SNAPSHOT.jar!/META-INF/cocoon/spring/block.xml] is invalid; nested exception is org.xml.sax.SAXParseException: cvc-elt.1: Cannot find the declaration of element 'property'.
Caused by: org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 2 in XML document from URL [jar:file:/home/geindre/.m2/repository/fr/meteo/advanced/1.0-SNAPSHOT/advanced-1.0-SNAPSHOT.jar!/META-INF/cocoon/spring/block.xml] is invalid; nested exception is org.xml.sax.SAXParseException: cvc-elt.1: Cannot find the declaration of element 'property'.
Caused by: org.xml.sax.SAXParseException: cvc-elt.1: Cannot find the declaration of element 'property'.
        at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
The question is is it possible to change the URL :
http://myMachine:port/myWebApplication/myBlock/resource
to http://myMachine:port/resource ???
Sébastien Geindre
DPREVI/AERO/DEV
sebastien.geindre __at__ meteo.fr
Hi Sébastien,
Not exactly sure what you are getting at here... What documentation is
this? Did you get the wrong mailing list? :slight_smile:
To do this, edit
the element
to
nested exception is
Caused by:
        at
Source)
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Sorry, i made an error in the mailing list....
to
Sébastien Geindre
DPREVI/AERO/DEV
