[Geoserver-users] moving workspaces: The specified coverageName is unavailable
Hi folks,
i'm moving workspaces from one server(Windows2008 Server) to another one. It is an raster(imagemosaic) workspace where on the new server i also have to point to a new datastore.
Reconfiguring the 'old' datastore connection and pointing to the new raster files also works fine, a new shape file and sample _image ist generated in the new data folder.
But when i am reconfiguring the raster layer that uses this datastore and whant to set up the new boundig box (Compute from data) i always get an error. The following message shows up:
java.lang.IllegalArgumentException: The specified coverageName is unavailable
I also get the error when clicking 'Dimensions'.
What i am doing wrong? Is it not possible to point to a new dataset an recalculate the new bounds?
Thanks in advance for any suggestion and best regards,
Toni
Anyone an idea?
To simplify my question, what i want to to is to reconfigure my layer configuration based on an a reconfigured image mosaic source (i point to the new shape file, that is generated based on the new raster datasets).
Thanks and regards,
Toni
Am 2015-05-21 18:43, schrieb Toni Pignataro:
Hi folks,
unavailable
Toni
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
On Thu, May 21, 2015 at 6:43 PM, Toni Pignataro <
toni.pignataro@anonymised.com> wrote:
Hi folks,
I'm afraid we don't have a good story for moving parts of configuration.
All the XML files are using ids to link to each other, when you take
a workspace from one server and move it to another, you'll get
dangling references to global styles and other configuration bits
and things will be hardly working, and somehow difficult to fix by hand.
If your workspace contains only local styles, you might have a chance
of that working (by accident, not by design), but local workspace
styles have been playing badly with integrated tile caching until 2.7.x,
so if you have a older version, that's not a solution either.
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Fri, May 22, 2015 at 2:09 PM, Toni Pignataro <
Hi Andrea and thanks for the advice.
What do you think, would it help to move the entire data_dir and then
reconfigue the image mosaic datasource?
That should work, yes
Ciao
Ing. Andrea Aime
@geowolf
Technical Lead
