OK the nightly build fixed 1a. Yay! thanks
I also tried the dataset I was using for 1a under 1b conditions and it
worked fine so 1b has transformed into a different problem (unrelated to
path). For this particular dataset the individual MrSID files work fine but
when accessed as a mosaic I get the affineTransform error from my first
message
Here is the gdalinfo for one of those MrSID files
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
Files: K_12c.sid
K_12c.sid.aux.xml
Size is 36480, 20480
Coordinate System is `'
Origin = (2447879.791000000200000,6980119.803999999500000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Metadata:
IMAGE__COMPRESSION_BLOCK_SIZE=1024
IMAGE__COMPRESSION_GAMMA=2.000000
IMAGE__COMPRESSION_NLEV=9
IMAGE__COMPRESSION_VERSION=2,0,0
IMAGE__COMPRESSION_WEIGHT=4.000000
IMAGE__CREATION_DATE=Tue Nov 13 14:07:45 2007
IMAGE__DYNAMIC_RANGE_LEVEL=127.500000
IMAGE__DYNAMIC_RANGE_WINDOW=256.000000
IMAGE__ENCODING_APPLICATION=GeoExpress 6.1.1.1513
IMAGE__INPUT_FILE_SIZE=2241696280.000000
IMAGE__INPUT_FORMAT=TIFF w/ World File
IMAGE__INPUT_NAME=I:\4-Deliverables\07106\Irving_orthos_TIFs\K_12C.tif
IMAGE__TARGET_COMPRESSION_RATIO=18.000000
IMAGE__WIDTH=36480
IMAGE__HEIGHT=20480
IMAGE__COLOR_SCHEME=0
IMAGE__DATA_TYPE=0
IMAGE__BITS_PER_SAMPLE=8
IMAGE__XY_ORIGIN=2447880.041000,6980119.554000
IMAGE__X_RESOLUTION=0.500000
IMAGE__Y_RESOLUTION=0.500000
VERSION=MG2
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 2447879.791, 6980119.804)
Lower Left ( 2447879.791, 6969879.804)
Upper Right ( 2466119.791, 6980119.804)
Lower Right ( 2466119.791, 6969879.804)
Center ( 2456999.791, 6974999.804)
Band 1 Block=1024x128 Type=Byte, ColorInterp=Red
Minimum=52.000, Maximum=171.000, Mean=97.686, StdDev=15.244
Overviews: 18240x10240, 9120x5120, 4560x2560, 2280x1280, 1140x640,
570x320, 285x160, 143x80, 72x40
Metadata:
LAYER_TYPE=athematic
STATISTICS_HISTOBINVALUES=12288|4096|4096|16384|8192|4096|4096|4096|20480|16
384|20480|24576|12288|32768|36864|49152|40960|36864|36864|77824|61440|77824|
86016|86016|90112|81920|81920|69632|147456|114688|118784|147456|147456|13926
4|151552|172032|204800|233472|208896|299008|348160|380928|409600|450560|6062
08|573440|692224|770048|802816|950272|1110016|1171456|1306624|1552384|168345
6|1806336|2154496|2486272|2666496|2826240|3477504|3743744|4194304|4472832|50
42176|5492736|5709824|6144000|6483968|6807552|7389184|7565312|8478720|847462
4|8937472|9211904|9146368|9703424|10219520|10260480|10215424|10682368|110100
48|11272192|11870208|11644928|12091392|12857344|13078528|13451264|13684736|1
3963264|13508608|14200832|14151680|13824000|13737984|13717504|13959168|13991
936|13262848|13262848|12681216|12099584|11632640|11493376|11014144|10272768|
10051584|9723904|8826880|9031680|8269824|8048640|7643136|7335936|6836224|636
9280|6307840|6000640|5545984|5443584|5177344|5070848|4993024|4583424|4448256
|4534272|4399104|4136960|4014080|4055040|3952640|3637248|3448832|3289088|316
6208|3141632|2936832|2641920|2805760|2613248|2293760|2158592|2170880|2056192
|1998848|1986560|1929216|1699840|1658880|1409024|1519616|1413120|1327104|124
9280|1159168|1163264|1101824|1019904|995328|983040|868352|831488|778240|7495
68|638976|569344|487424|577536|512000|442368|425984|327680|335872|344064|327
680|258048|307200|319488|262144|217088|188416|155648|225280|118784|172032|13
1072|90112|77824|65536|73728|73728|40960|53248|45056|73728|36864|36864|69632
|12288|40960|28672|36864|20480|28672|32768|32768|20480|20480|12288|20480|819
2|16384|16384|12288|16384|8192|20480|4096|4096|16384|8192|0|8192|0|8192|8192
|0|0|4096|16384|0|0|0|0|4096|4096|0|4096|4096|0|0|0|0|0|4096|0|0|0|0|4096|
<GDALRasterAttributeTable>
<FieldDefn index="0">
<Name>Histogram</Name>
<Type>0</Type>
<Usage>0</Usage>
</FieldDefn>
<Row index="0">
<F>12288</F>
</Row>
<Row index="1">
<F>4096</F>
</Row>
<Row index="2">
<F>4096</F>
</Row>
<Row index="3">
<F>16384</F>
</Row>
<Row index="4">
<F>8192</F>
</Row>
<Row index="5">
<F>4096</F>
</Row>
<Row index="6">
<F>4096</F>
</Row>
<Row index="7">
<F>4096</F>
</Row>
<Row index="8">
<F>20480</F>
</Row>
<Row index="9">
<F>16384</F>
</Row>
<Row index="10">
<F>20480</F>
</Row>
<Row index="11">
<F>24576</F>
</Row>
<Row index="12">
<F>12288</F>
</Row>
<Row index="13">
<F>32768</F>
</Row>
<Row index="14">
<F>36864</F>
</Row>
<Row index="15">
<F>49152</F>
</Row>
<Row index="16">
<F>40960</F>
</Row>
<Row index="17">
<F>36864</F>
</Row>
<Row index="18">
<F>36864</F>
</Row>
<Row index="19">
<F>77824</F>
</Row>
<Row index="20">
<F>61440</F>
</Row>
<Row index="21">
<F>77824</F>
</Row>
<Row index="22">
<F>86016</F>
</Row>
<Row index="23">
<F>86016</F>
</Row>
<Row index="24">
<F>90112</F>
</Row>
<Row index="25">
<F>81920</F>
</Row>
<Row index="26">
<F>81920</F>
</Row>
<Row index="27">
<F>69632</F>
</Row>
<Row index="28">
<F>147456</F>
</Row>
<Row index="29">
<F>114688</F>
</Row>
<Row index="30">
<F>118784</F>
</Row>
<Row index="31">
<F>147456</F>
</Row>
<Row index="32">
<F>147456</F>
</Row>
<Row index="33">
<F>139264</F>
</Row>
<Row index="34">
<F>151552</F>
</Row>
<Row index="35">
<F>172032</F>
</Row>
<Row index="36">
<F>204800</F>
</Row>
<Row index="37">
<F>233472</F>
</Row>
<Row index="38">
<F>208896</F>
</Row>
<Row index="39">
<F>299008</F>
</Row>
<Row index="40">
<F>348160</F>
</Row>
<Row index="41">
<F>380928</F>
</Row>
<Row index="42">
<F>409600</F>
</Row>
<Row index="43">
<F>450560</F>
</Row>
<Row index="44">
<F>606208</F>
</Row>
<Row index="45">
<F>573440</F>
</Row>
<Row index="46">
<F>692224</F>
</Row>
<Row index="47">
<F>770048</F>
</Row>
<Row index="48">
<F>802816</F>
</Row>
<Row index="49">
<F>950272</F>
</Row>
<Row index="50">
<F>1110016</F>
</Row>
<Row index="51">
<F>1171456</F>
</Row>
<Row index="52">
<F>1306624</F>
</Row>
<Row index="53">
<F>1552384</F>
</Row>
<Row index="54">
<F>1683456</F>
</Row>
<Row index="55">
<F>1806336</F>
</Row>
<Row index="56">
<F>2154496</F>
</Row>
<Row index="57">
<F>2486272</F>
</Row>
<Row index="58">
<F>2666496</F>
</Row>
<Row index="59">
<F>2826240</F>
</Row>
<Row index="60">
<F>3477504</F>
</Row>
<Row index="61">
<F>3743744</F>
</Row>
<Row index="62">
<F>4194304</F>
</Row>
<Row index="63">
<F>4472832</F>
</Row>
<Row index="64">
<F>5042176</F>
</Row>
<Row index="65">
<F>5492736</F>
</Row>
<Row index="66">
<F>5709824</F>
</Row>
<Row index="67">
<F>6144000</F>
</Row>
<Row index="68">
<F>6483968</F>
</Row>
<Row index="69">
<F>6807552</F>
</Row>
<Row index="70">
<F>7389184</F>
</Row>
<Row index="71">
<F>7565312</F>
</Row>
<Row index="72">
<F>8478720</F>
</Row>
<Row index="73">
<F>8474624</F>
</Row>
<Row index="74">
<F>8937472</F>
</Row>
<Row index="75">
<F>9211904</F>
</Row>
<Row index="76">
<F>9146368</F>
</Row>
<Row index="77">
<F>9703424</F>
</Row>
<Row index="78">
<F>10219520</F>
</Row>
<Row index="79">
<F>10260480</F>
</Row>
<Row index="80">
<F>10215424</F>
</Row>
<Row index="81">
<F>10682368</F>
</Row>
<Row index="82">
<F>11010048</F>
</Row>
<Row index="83">
<F>11272192</F>
</Row>
<Row index="84">
<F>11870208</F>
</Row>
<Row index="85">
<F>11644928</F>
</Row>
<Row index="86">
<F>12091392</F>
</Row>
<Row index="87">
<F>12857344</F>
</Row>
<Row index="88">
<F>13078528</F>
</Row>
<Row index="89">
<F>13451264</F>
</Row>
<Row index="90">
<F>13684736</F>
</Row>
<Row index="91">
<F>13963264</F>
</Row>
<Row index="92">
<F>13508608</F>
</Row>
<Row index="93">
<F>14200832</F>
</Row>
<Row index="94">
<F>14151680</F>
</Row>
<Row index="95">
<F>13824000</F>
</Row>
<Row index="96">
<F>13737984</F>
</Row>
<Row index="97">
<F>13717504</F>
</Row>
<Row index="98">
<F>13959168</F>
</Row>
<Row index="99">
<F>13991936</F>
</Row>
<Row index="100">
<F>13262848</F>
</Row>
<Row index="101">
<F>13262848</F>
</Row>
<Row index="102">
<F>12681216</F>
</Row>
<Row index="103">
<F>12099584</F>
</Row>
<Row index="104">
<F>11632640</F>
</Row>
<Row index="105">
<F>11493376</F>
</Row>
<Row index="106">
<F>11014144</F>
</Row>
<Row index="107">
<F>10272768</F>
</Row>
<Row index="108">
<F>10051584</F>
</Row>
<Row index="109">
<F>9723904</F>
</Row>
<Row index="110">
<F>8826880</F>
</Row>
<Row index="111">
<F>9031680</F>
</Row>
<Row index="112">
<F>8269824</F>
</Row>
<Row index="113">
<F>8048640</F>
</Row>
<Row index="114">
<F>7643136</F>
</Row>
<Row index="115">
<F>7335936</F>
</Row>
<Row index="116">
<F>6836224</F>
</Row>
<Row index="117">
<F>6369280</F>
</Row>
<Row index="118">
<F>6307840</F>
</Row>
<Row index="119">
<F>6000640</F>
</Row>
<Row index="120">
<F>5545984</F>
</Row>
<Row index="121">
<F>5443584</F>
</Row>
<Row index="122">
<F>5177344</F>
</Row>
<Row index="123">
<F>5070848</F>
</Row>
<Row index="124">
<F>4993024</F>
</Row>
<Row index="125">
<F>4583424</F>
</Row>
<Row index="126">
<F>4448256</F>
</Row>
<Row index="127">
<F>4534272</F>
</Row>
<Row index="128">
<F>4399104</F>
</Row>
<Row index="129">
<F>4136960</F>
</Row>
<Row index="130">
<F>4014080</F>
</Row>
<Row index="131">
<F>4055040</F>
</Row>
<Row index="132">
<F>3952640</F>
</Row>
<Row index="133">
<F>3637248</F>
</Row>
<Row index="134">
<F>3448832</F>
</Row>
<Row index="135">
<F>3289088</F>
</Row>
<Row index="136">
<F>3166208</F>
</Row>
<Row index="137">
<F>3141632</F>
</Row>
<Row index="138">
<F>2936832</F>
</Row>
<Row index="139">
<F>2641920</F>
</Row>
<Row index="140">
<F>2805760</F>
</Row>
<Row index="141">
<F>2613248</F>
</Row>
<Row index="142">
<F>2293760</F>
</Row>
<Row index="143">
<F>2158592</F>
</Row>
<Row index="144">
<F>2170880</F>
</Row>
<Row index="145">
<F>2056192</F>
</Row>
<Row index="146">
<F>1998848</F>
</Row>
<Row index="147">
<F>1986560</F>
</Row>
<Row index="148">
<F>1929216</F>
</Row>
<Row index="149">
<F>1699840</F>
</Row>
<Row index="150">
<F>1658880</F>
</Row>
<Row index="151">
<F>1409024</F>
</Row>
<Row index="152">
<F>1519616</F>
</Row>
<Row index="153">
<F>1413120</F>
</Row>
<Row index="154">
<F>1327104</F>
</Row>
<Row index="155">
<F>1249280</F>
</Row>
<Row index="156">
<F>1159168</F>
</Row>
<Row index="157">
<F>1163264</F>
</Row>
<Row index="158">
<F>1101824</F>
</Row>
<Row index="159">
<F>1019904</F>
</Row>
<Row index="160">
<F>995328</F>
</Row>
<Row index="161">
<F>983040</F>
</Row>
<Row index="162">
<F>868352</F>
</Row>
<Row index="163">
<F>831488</F>
</Row>
<Row index="164">
<F>778240</F>
</Row>
<Row index="165">
<F>749568</F>
</Row>
<Row index="166">
<F>638976</F>
</Row>
<Row index="167">
<F>569344</F>
</Row>
<Row index="168">
<F>487424</F>
</Row>
<Row index="169">
<F>577536</F>
</Row>
<Row index="170">
<F>512000</F>
</Row>
<Row index="171">
<F>442368</F>
</Row>
<Row index="172">
<F>425984</F>
</Row>
<Row index="173">
<F>327680</F>
</Row>
<Row index="174">
<F>335872</F>
</Row>
<Row index="175">
<F>344064</F>
</Row>
<Row index="176">
<F>327680</F>
</Row>
<Row index="177">
<F>258048</F>
</Row>
<Row index="178">
<F>307200</F>
</Row>
<Row index="179">
<F>319488</F>
</Row>
<Row index="180">
<F>262144</F>
</Row>
<Row index="181">
<F>217088</F>
</Row>
<Row index="182">
<F>188416</F>
</Row>
<Row index="183">
<F>155648</F>
</Row>
<Row index="184">
<F>225280</F>
</Row>
<Row index="185">
<F>118784</F>
</Row>
<Row index="186">
<F>172032</F>
</Row>
<Row index="187">
<F>131072</F>
</Row>
<Row index="188">
<F>90112</F>
</Row>
<Row index="189">
<F>77824</F>
</Row>
<Row index="190">
<F>65536</F>
</Row>
<Row index="191">
<F>73728</F>
</Row>
<Row index="192">
<F>73728</F>
</Row>
<Row index="193">
<F>40960</F>
</Row>
<Row index="194">
<F>53248</F>
</Row>
<Row index="195">
<F>45056</F>
</Row>
<Row index="196">
<F>73728</F>
</Row>
<Row index="197">
<F>36864</F>
</Row>
<Row index="198">
<F>36864</F>
</Row>
<Row index="199">
<F>69632</F>
</Row>
<Row index="200">
<F>12288</F>
</Row>
<Row index="201">
<F>40960</F>
</Row>
<Row index="202">
<F>28672</F>
</Row>
<Row index="203">
<F>36864</F>
</Row>
<Row index="204">
<F>20480</F>
</Row>
<Row index="205">
<F>28672</F>
</Row>
<Row index="206">
<F>32768</F>
</Row>
<Row index="207">
<F>32768</F>
</Row>
<Row index="208">
<F>20480</F>
</Row>
<Row index="209">
<F>20480</F>
</Row>
<Row index="210">
<F>12288</F>
</Row>
<Row index="211">
<F>20480</F>
</Row>
<Row index="212">
<F>8192</F>
</Row>
<Row index="213">
<F>16384</F>
</Row>
<Row index="214">
<F>16384</F>
</Row>
<Row index="215">
<F>12288</F>
</Row>
<Row index="216">
<F>16384</F>
</Row>
<Row index="217">
<F>8192</F>
</Row>
<Row index="218">
<F>20480</F>
</Row>
<Row index="219">
<F>4096</F>
</Row>
<Row index="220">
<F>4096</F>
</Row>
<Row index="221">
<F>16384</F>
</Row>
<Row index="222">
<F>8192</F>
</Row>
<Row index="223">
<F>0</F>
</Row>
<Row index="224">
<F>8192</F>
</Row>
<Row index="225">
<F>0</F>
</Row>
<Row index="226">
<F>8192</F>
</Row>
<Row index="227">
<F>8192</F>
</Row>
<Row index="228">
<F>0</F>
</Row>
<Row index="229">
<F>0</F>
</Row>
<Row index="230">
<F>4096</F>
</Row>
<Row index="231">
<F>16384</F>
</Row>
<Row index="232">
<F>0</F>
</Row>
<Row index="233">
<F>0</F>
</Row>
<Row index="234">
<F>0</F>
</Row>
<Row index="235">
<F>0</F>
</Row>
<Row index="236">
<F>4096</F>
</Row>
<Row index="237">
<F>4096</F>
</Row>
<Row index="238">
<F>0</F>
</Row>
<Row index="239">
<F>4096</F>
</Row>
<Row index="240">
<F>4096</F>
</Row>
<Row index="241">
<F>0</F>
</Row>
<Row index="242">
<F>0</F>
</Row>
<Row index="243">
<F>0</F>
</Row>
<Row index="244">
<F>0</F>
</Row>
<Row index="245">
<F>0</F>
</Row>
<Row index="246">
<F>4096</F>
</Row>
<Row index="247">
<F>0</F>
</Row>
<Row index="248">
<F>0</F>
</Row>
<Row index="249">
<F>0</F>
</Row>
<Row index="250">
<F>0</F>
</Row>
<Row index="251">
<F>4096</F>
</Row>
</GDALRasterAttributeTable>
Band 2 Block=1024x128 Type=Byte, ColorInterp=Green
Minimum=57.000, Maximum=175.000, Mean=100.840, StdDev=14.883
Metadata:
STATISTICS_HISTOBINVALUES=12288|0|8192|4096|12288|8192|4096|0|8192|8192|4096
|0|4096|0|0|8192|12288|4096|12288|12288|4096|8192|16384|4096|32768|45056|450
56|49152|69632|73728|94208|86016|86016|86016|86016|102400|118784|118784|1433
60|155648|147456|167936|196608|274432|270336|294912|335872|450560|499712|618
496|651264|712704|843776|921600|946176|1097728|1228800|1486848|1691648|17080
32|1966080|2318336|2584576|2789376|3502080|3571712|3842048|4284416|4947968|5
173248|5685248|6168576|6340608|6901760|7229440|7794688|8429568|8499200|92897
28|9203712|9363456|9998336|10027008|10752000|11055104|11382784|11689984|1207
5008|12484608|13643776|14147584|13934592|14381056|14589952|14381056|15163392
|15233024|14987264|14376960|14462976|14225408|14176256|13955072|13402112|135
12704|13258752|13279232|12898304|12288000|12288000|11554816|10833920|1012121
6|9654272|9408512|8769536|8339456|7770112|7311360|6676480|6332416|6098944|57
05728|5414912|4968448|4661248|4653056|4571136|4370432|4386816|4063232|394035
2|3661824|3796992|3502080|3231744|3252224|3182592|2895872|2965504|2592768|25
35424|2174976|2424832|2076672|2105344|2052096|1957888|1880064|1753088|171622
4|1466368|1695744|1462272|1290240|1273856|1314816|1216512|1011712|1060864|10
19904|1048576|970752|962560|864256|745472|659456|778240|720896|626688|659456
|618496|520192|618496|462848|434176|389120|417792|364544|397312|327680|33587
2|303104|253952|241664|176128|188416|192512|110592|147456|172032|147456|1228
80|163840|98304|122880|98304|86016|77824|90112|65536|77824|98304|40960|40960
|20480|32768|40960|20480|32768|45056|40960|45056|49152|36864|36864|53248|368
64|12288|32768|20480|16384|36864|24576|16384|28672|4096|16384|16384|16384|81
92|12288|12288|12288|12288|0|8192|0|0|4096|4096|0|16384|4096|4096|0|8192|0|4
096|0|0|4096|0|0|12288|4096|
<Type>0</Type>
<Usage>0</Usage>
</FieldDefn>
<Row index="0">
<F>12288</F>
</Row>
<Row index="1">
<F>0</F>
</Row>
<Row index="2">
<F>8192</F>
</Row>
<Row index="3">
<F>4096</F>
</Row>
<Row index="4">
<F>12288</F>
</Row>
<Row index="5">
<F>8192</F>
</Row>
<Row index="6">
<F>4096</F>
</Row>
<Row index="7">
<F>0</F>
</Row>
<Row index="8">
<F>8192</F>
</Row>
<Row index="9">
<F>8192</F>
</Row>
<Row index="10">
<F>4096</F>
</Row>
<Row index="11">
<F>0</F>
</Row>
<Row index="12">
<F>4096</F>
</Row>
<Row index="13">
<F>0</F>
</Row>
<Row index="14">
<F>0</F>
</Row>
<Row index="15">
<F>8192</F>
</Row>
<Row index="16">
<F>12288</F>
</Row>
<Row index="17">
<F>4096</F>
</Row>
<Row index="18">
<F>12288</F>
</Row>
<Row index="19">
<F>12288</F>
</Row>
<Row index="20">
<F>4096</F>
</Row>
<Row index="21">
<F>8192</F>
</Row>
<Row index="22">
<F>16384</F>
</Row>
<Row index="23">
<F>4096</F>
</Row>
<Row index="24">
<F>32768</F>
</Row>
<Row index="25">
<F>45056</F>
</Row>
<Row index="26">
<F>45056</F>
</Row>
<Row index="27">
<F>49152</F>
</Row>
<Row index="28">
<F>69632</F>
</Row>
<Row index="29">
<F>73728</F>
</Row>
<Row index="30">
<F>94208</F>
</Row>
<Row index="31">
<F>86016</F>
</Row>
<Row index="32">
<F>86016</F>
</Row>
<Row index="33">
<F>86016</F>
</Row>
<Row index="34">
<F>86016</F>
</Row>
<Row index="35">
<F>102400</F>
</Row>
<Row index="36">
<F>118784</F>
</Row>
<Row index="37">
<F>118784</F>
</Row>
<Row index="38">
<F>143360</F>
</Row>
<Row index="39">
<F>155648</F>
</Row>
<Row index="40">
<F>147456</F>
</Row>
<Row index="41">
<F>167936</F>
</Row>
<Row index="42">
<F>196608</F>
</Row>
<Row index="43">
<F>274432</F>
</Row>
<Row index="44">
<F>270336</F>
</Row>
<Row index="45">
<F>294912</F>
</Row>
<Row index="46">
<F>335872</F>
</Row>
<Row index="47">
<F>450560</F>
</Row>
<Row index="48">
<F>499712</F>
</Row>
<Row index="49">
<F>618496</F>
</Row>
<Row index="50">
<F>651264</F>
</Row>
<Row index="51">
<F>712704</F>
</Row>
<Row index="52">
<F>843776</F>
</Row>
<Row index="53">
<F>921600</F>
</Row>
<Row index="54">
<F>946176</F>
</Row>
<Row index="55">
<F>1097728</F>
</Row>
<Row index="56">
<F>1228800</F>
</Row>
<Row index="57">
<F>1486848</F>
</Row>
<Row index="58">
<F>1691648</F>
</Row>
<Row index="59">
<F>1708032</F>
</Row>
<Row index="60">
<F>1966080</F>
</Row>
<Row index="61">
<F>2318336</F>
</Row>
<Row index="62">
<F>2584576</F>
</Row>
<Row index="63">
<F>2789376</F>
</Row>
<Row index="64">
<F>3502080</F>
</Row>
<Row index="65">
<F>3571712</F>
</Row>
<Row index="66">
<F>3842048</F>
</Row>
<Row index="67">
<F>4284416</F>
</Row>
<Row index="68">
<F>4947968</F>
</Row>
<Row index="69">
<F>5173248</F>
</Row>
<Row index="70">
<F>5685248</F>
</Row>
<Row index="71">
<F>6168576</F>
</Row>
<Row index="72">
<F>6340608</F>
</Row>
<Row index="73">
<F>6901760</F>
</Row>
<Row index="74">
<F>7229440</F>
</Row>
<Row index="75">
<F>7794688</F>
</Row>
<Row index="76">
<F>8429568</F>
</Row>
<Row index="77">
<F>8499200</F>
</Row>
<Row index="78">
<F>9289728</F>
</Row>
<Row index="79">
<F>9203712</F>
</Row>
<Row index="80">
<F>9363456</F>
</Row>
<Row index="81">
<F>9998336</F>
</Row>
<Row index="82">
<F>10027008</F>
</Row>
<Row index="83">
<F>10752000</F>
</Row>
<Row index="84">
<F>11055104</F>
</Row>
<Row index="85">
<F>11382784</F>
</Row>
<Row index="86">
<F>11689984</F>
</Row>
<Row index="87">
<F>12075008</F>
</Row>
<Row index="88">
<F>12484608</F>
</Row>
<Row index="89">
<F>13643776</F>
</Row>
<Row index="90">
<F>14147584</F>
</Row>
<Row index="91">
<F>13934592</F>
</Row>
<Row index="92">
<F>14381056</F>
</Row>
<Row index="93">
<F>14589952</F>
</Row>
<Row index="94">
<F>14381056</F>
</Row>
<Row index="95">
<F>15163392</F>
</Row>
<Row index="96">
<F>15233024</F>
</Row>
<Row index="97">
<F>14987264</F>
</Row>
<Row index="98">
<F>14376960</F>
</Row>
<Row index="99">
<F>14462976</F>
</Row>
<Row index="100">
<F>14225408</F>
</Row>
<Row index="101">
<F>14176256</F>
</Row>
<Row index="102">
<F>13955072</F>
</Row>
<Row index="103">
<F>13402112</F>
</Row>
<Row index="104">
<F>13512704</F>
</Row>
<Row index="105">
<F>13258752</F>
</Row>
<Row index="106">
<F>13279232</F>
</Row>
<Row index="107">
<F>12898304</F>
</Row>
<Row index="108">
<F>12288000</F>
</Row>
<Row index="109">
<F>12288000</F>
</Row>
<Row index="110">
<F>11554816</F>
</Row>
<Row index="111">
<F>10833920</F>
</Row>
<Row index="112">
<F>10121216</F>
</Row>
<Row index="113">
<F>9654272</F>
</Row>
<Row index="114">
<F>9408512</F>
</Row>
<Row index="115">
<F>8769536</F>
</Row>
<Row index="116">
<F>8339456</F>
</Row>
<Row index="117">
<F>7770112</F>
</Row>
<Row index="118">
<F>7311360</F>
</Row>
<Row index="119">
<F>6676480</F>
</Row>
<Row index="120">
<F>6332416</F>
</Row>
<Row index="121">
<F>6098944</F>
</Row>
<Row index="122">
<F>5705728</F>
</Row>
<Row index="123">
<F>5414912</F>
</Row>
<Row index="124">
<F>4968448</F>
</Row>
<Row index="125">
<F>4661248</F>
</Row>
<Row index="126">
<F>4653056</F>
</Row>
<Row index="127">
<F>4571136</F>
</Row>
<Row index="128">
<F>4370432</F>
</Row>
<Row index="129">
<F>4386816</F>
</Row>
<Row index="130">
<F>4063232</F>
</Row>
<Row index="131">
<F>3940352</F>
</Row>
<Row index="132">
<F>3661824</F>
</Row>
<Row index="133">
<F>3796992</F>
</Row>
<Row index="134">
<F>3502080</F>
</Row>
<Row index="135">
<F>3231744</F>
</Row>
<Row index="136">
<F>3252224</F>
</Row>
<Row index="137">
<F>3182592</F>
</Row>
<Row index="138">
<F>2895872</F>
</Row>
<Row index="139">
<F>2965504</F>
</Row>
<Row index="140">
<F>2592768</F>
</Row>
<Row index="141">
<F>2535424</F>
</Row>
<Row index="142">
<F>2174976</F>
</Row>
<Row index="143">
<F>2424832</F>
</Row>
<Row index="144">
<F>2076672</F>
</Row>
<Row index="145">
<F>2105344</F>
</Row>
<Row index="146">
<F>2052096</F>
</Row>
<Row index="147">
<F>1957888</F>
</Row>
<Row index="148">
<F>1880064</F>
</Row>
<Row index="149">
<F>1753088</F>
</Row>
<Row index="150">
<F>1716224</F>
</Row>
<Row index="151">
<F>1466368</F>
</Row>
<Row index="152">
<F>1695744</F>
</Row>
<Row index="153">
<F>1462272</F>
</Row>
<Row index="154">
<F>1290240</F>
</Row>
<Row index="155">
<F>1273856</F>
</Row>
<Row index="156">
<F>1314816</F>
</Row>
<Row index="157">
<F>1216512</F>
</Row>
<Row index="158">
<F>1011712</F>
</Row>
<Row index="159">
<F>1060864</F>
</Row>
<Row index="160">
<F>1019904</F>
</Row>
<Row index="161">
<F>1048576</F>
</Row>
<Row index="162">
<F>970752</F>
</Row>
<Row index="163">
<F>962560</F>
</Row>
<Row index="164">
<F>864256</F>
</Row>
<Row index="165">
<F>745472</F>
</Row>
<Row index="166">
<F>659456</F>
</Row>
<Row index="167">
<F>778240</F>
</Row>
<Row index="168">
<F>720896</F>
</Row>
<Row index="169">
<F>626688</F>
</Row>
<Row index="170">
<F>659456</F>
</Row>
<Row index="171">
<F>618496</F>
</Row>
<Row index="172">
<F>520192</F>
</Row>
<Row index="173">
<F>618496</F>
</Row>
<Row index="174">
<F>462848</F>
</Row>
<Row index="175">
<F>434176</F>
</Row>
<Row index="176">
<F>389120</F>
</Row>
<Row index="177">
<F>417792</F>
</Row>
<Row index="178">
<F>364544</F>
</Row>
<Row index="179">
<F>397312</F>
</Row>
<Row index="180">
<F>327680</F>
</Row>
<Row index="181">
<F>335872</F>
</Row>
<Row index="182">
<F>303104</F>
</Row>
<Row index="183">
<F>253952</F>
</Row>
<Row index="184">
<F>241664</F>
</Row>
<Row index="185">
<F>176128</F>
</Row>
<Row index="186">
<F>188416</F>
</Row>
<Row index="187">
<F>192512</F>
</Row>
<Row index="188">
<F>110592</F>
</Row>
<Row index="189">
<F>147456</F>
</Row>
<Row index="190">
<F>172032</F>
</Row>
<Row index="191">
<F>147456</F>
</Row>
<Row index="192">
<F>122880</F>
</Row>
<Row index="193">
<F>163840</F>
</Row>
<Row index="194">
<F>98304</F>
</Row>
<Row index="195">
<F>122880</F>
</Row>
<Row index="196">
<F>98304</F>
</Row>
<Row index="197">
<F>86016</F>
</Row>
<Row index="198">
<F>77824</F>
</Row>
<Row index="199">
<F>90112</F>
</Row>
<Row index="200">
<F>65536</F>
</Row>
<Row index="201">
<F>77824</F>
</Row>
<Row index="202">
<F>98304</F>
</Row>
<Row index="203">
<F>40960</F>
</Row>
<Row index="204">
<F>40960</F>
</Row>
<Row index="205">
<F>20480</F>
</Row>
<Row index="206">
<F>32768</F>
</Row>
<Row index="207">
<F>40960</F>
</Row>
<Row index="208">
<F>20480</F>
</Row>
<Row index="209">
<F>32768</F>
</Row>
<Row index="210">
<F>45056</F>
</Row>
<Row index="211">
<F>40960</F>
</Row>
<Row index="212">
<F>45056</F>
</Row>
<Row index="213">
<F>49152</F>
</Row>
<Row index="214">
<F>36864</F>
</Row>
<Row index="215">
<F>36864</F>
</Row>
<Row index="216">
<F>53248</F>
</Row>
<Row index="217">
<F>36864</F>
</Row>
<Row index="218">
<F>12288</F>
</Row>
<Row index="219">
<F>32768</F>
</Row>
<Row index="220">
<F>20480</F>
</Row>
<Row index="221">
<F>16384</F>
</Row>
<Row index="222">
<F>36864</F>
</Row>
<Row index="223">
<F>24576</F>
</Row>
<Row index="224">
<F>16384</F>
</Row>
<Row index="225">
<F>28672</F>
</Row>
<Row index="226">
<F>4096</F>
</Row>
<Row index="227">
<F>16384</F>
</Row>
<Row index="228">
<F>16384</F>
</Row>
<Row index="229">
<F>16384</F>
</Row>
<Row index="230">
<F>8192</F>
</Row>
<Row index="231">
<F>12288</F>
</Row>
<Row index="232">
<F>12288</F>
</Row>
<Row index="233">
<F>12288</F>
</Row>
<Row index="234">
<F>12288</F>
</Row>
<Row index="235">
<F>0</F>
</Row>
<Row index="236">
<F>8192</F>
</Row>
<Row index="237">
<F>0</F>
</Row>
<Row index="238">
<F>0</F>
</Row>
<Row index="239">
<F>4096</F>
</Row>
<Row index="240">
<F>4096</F>
</Row>
<Row index="241">
<F>0</F>
</Row>
<Row index="242">
<F>16384</F>
</Row>
<Row index="243">
<F>4096</F>
</Row>
<Row index="244">
<F>4096</F>
</Row>
<Row index="245">
<F>0</F>
</Row>
<Row index="246">
<F>8192</F>
</Row>
<Row index="247">
<F>0</F>
</Row>
<Row index="248">
<F>4096</F>
</Row>
<Row index="249">
<F>0</F>
</Row>
<Row index="250">
<F>0</F>
</Row>
<Row index="251">
<F>4096</F>
</Row>
<Row index="252">
<F>0</F>
</Row>
<Row index="253">
<F>0</F>
</Row>
<Row index="254">
<F>12288</F>
</Row>
<Row index="255">
<F>4096</F>
</Row>
Band 3 Block=1024x128 Type=Byte, ColorInterp=Blue
Minimum=35.000, Maximum=161.000, Mean=76.729, StdDev=16.070
Metadata:
STATISTICS_HISTOBINVALUES=0|4096|4096|8192|0|4096|4096|0|20480|8192|24576|32
768|32768|28672|57344|90112|81920|122880|126976|143360|176128|196608|237568|
258048|307200|380928|491520|507904|569344|610304|724992|913408|1077248|14540
80|1474560|1658880|1998848|2244608|2465792|2883584|3317760|3608576|4378624|4
902912|5246976|5394432|5902336|6369280|6873088|7258112|7667712|8265728|87244
80|9420800|9805824|10772480|11235328|11997184|12083200|12591104|13398016|137
05216|14110720|14839808|15290368|15388672|15470592|15958016|16396288|1538457
6|15728640|15384576|15200256|14934016|14766080|14569472|14082048|13807616|13
328384|12832768|11939840|11005952|10547200|10629120|9936896|9166848|8441856|
8335360|7905280|7450624|7323648|6950912|6631424|6242304|5861376|5779456|5201
920|5087232|5079040|5033984|4837376|4726784|4141056|4386816|3911680|3944448|
3661824|3510272|3592192|3375104|3100672|3072000|3018752|3059712|2584576|2666
496|2510848|2371584|2469888|2351104|2244608|2170880|2093056|2121728|1896448|
1830912|1794048|1679360|1548288|1581056|1536000|1384448|1359872|1335296|1331
200|1081344|1159168|1097728|999424|1130496|1032192|974848|921600|913408|8683
52|851968|729088|679936|655360|651264|655360|696320|643072|528384|614400|516
096|491520|557056|483328|413696|425984|385024|372736|352256|385024|335872|27
0336|258048|225280|274432|266240|237568|266240|180224|212992|241664|208896|2
29376|172032|143360|180224|176128|143360|155648|135168|143360|106496|139264|
135168|131072|94208|73728|53248|69632|53248|28672|20480|40960|57344|61440|28
672|24576|57344|61440|49152|40960|40960|53248|49152|36864|16384|4096|8192|12
288|12288|36864|16384|20480|12288|12288|16384|16384|8192|4096|12288|0|4096|1
2288|0|8192|12288|4096|4096|4096|4096|16384|0|0|0|0|4096|12288|4096|0|4096|0
|0|0|0|8192|
<Type>0</Type>
<Usage>0</Usage>
</FieldDefn>
<Row index="0">
<F>0</F>
</Row>
<Row index="1">
<F>4096</F>
</Row>
<Row index="2">
<F>4096</F>
</Row>
<Row index="3">
<F>8192</F>
</Row>
<Row index="4">
<F>0</F>
</Row>
<Row index="5">
<F>4096</F>
</Row>
<Row index="6">
<F>4096</F>
</Row>
<Row index="7">
<F>0</F>
</Row>
<Row index="8">
<F>20480</F>
</Row>
<Row index="9">
<F>8192</F>
</Row>
<Row index="10">
<F>24576</F>
</Row>
<Row index="11">
<F>32768</F>
</Row>
<Row index="12">
<F>32768</F>
</Row>
<Row index="13">
<F>28672</F>
</Row>
<Row index="14">
<F>57344</F>
</Row>
<Row index="15">
<F>90112</F>
</Row>
<Row index="16">
<F>81920</F>
</Row>
<Row index="17">
<F>122880</F>
</Row>
<Row index="18">
<F>126976</F>
</Row>
<Row index="19">
<F>143360</F>
</Row>
<Row index="20">
<F>176128</F>
</Row>
<Row index="21">
<F>196608</F>
</Row>
<Row index="22">
<F>237568</F>
</Row>
<Row index="23">
<F>258048</F>
</Row>
<Row index="24">
<F>307200</F>
</Row>
<Row index="25">
<F>380928</F>
</Row>
<Row index="26">
<F>491520</F>
</Row>
<Row index="27">
<F>507904</F>
</Row>
<Row index="28">
<F>569344</F>
</Row>
<Row index="29">
<F>610304</F>
</Row>
<Row index="30">
<F>724992</F>
</Row>
<Row index="31">
<F>913408</F>
</Row>
<Row index="32">
<F>1077248</F>
</Row>
<Row index="33">
<F>1454080</F>
</Row>
<Row index="34">
<F>1474560</F>
</Row>
<Row index="35">
<F>1658880</F>
</Row>
<Row index="36">
<F>1998848</F>
</Row>
<Row index="37">
<F>2244608</F>
</Row>
<Row index="38">
<F>2465792</F>
</Row>
<Row index="39">
<F>2883584</F>
</Row>
<Row index="40">
<F>3317760</F>
</Row>
<Row index="41">
<F>3608576</F>
</Row>
<Row index="42">
<F>4378624</F>
</Row>
<Row index="43">
<F>4902912</F>
</Row>
<Row index="44">
<F>5246976</F>
</Row>
<Row index="45">
<F>5394432</F>
</Row>
<Row index="46">
<F>5902336</F>
</Row>
<Row index="47">
<F>6369280</F>
</Row>
<Row index="48">
<F>6873088</F>
</Row>
<Row index="49">
<F>7258112</F>
</Row>
<Row index="50">
<F>7667712</F>
</Row>
<Row index="51">
<F>8265728</F>
</Row>
<Row index="52">
<F>8724480</F>
</Row>
<Row index="53">
<F>9420800</F>
</Row>
<Row index="54">
<F>9805824</F>
</Row>
<Row index="55">
<F>10772480</F>
</Row>
<Row index="56">
<F>11235328</F>
</Row>
<Row index="57">
<F>11997184</F>
</Row>
<Row index="58">
<F>12083200</F>
</Row>
<Row index="59">
<F>12591104</F>
</Row>
<Row index="60">
<F>13398016</F>
</Row>
<Row index="61">
<F>13705216</F>
</Row>
<Row index="62">
<F>14110720</F>
</Row>
<Row index="63">
<F>14839808</F>
</Row>
<Row index="64">
<F>15290368</F>
</Row>
<Row index="65">
<F>15388672</F>
</Row>
<Row index="66">
<F>15470592</F>
</Row>
<Row index="67">
<F>15958016</F>
</Row>
<Row index="68">
<F>16396288</F>
</Row>
<Row index="69">
<F>15384576</F>
</Row>
<Row index="70">
<F>15728640</F>
</Row>
<Row index="71">
<F>15384576</F>
</Row>
<Row index="72">
<F>15200256</F>
</Row>
<Row index="73">
<F>14934016</F>
</Row>
<Row index="74">
<F>14766080</F>
</Row>
<Row index="75">
<F>14569472</F>
</Row>
<Row index="76">
<F>14082048</F>
</Row>
<Row index="77">
<F>13807616</F>
</Row>
<Row index="78">
<F>13328384</F>
</Row>
<Row index="79">
<F>12832768</F>
</Row>
<Row index="80">
<F>11939840</F>
</Row>
<Row index="81">
<F>11005952</F>
</Row>
<Row index="82">
<F>10547200</F>
</Row>
<Row index="83">
<F>10629120</F>
</Row>
<Row index="84">
<F>9936896</F>
</Row>
<Row index="85">
<F>9166848</F>
</Row>
<Row index="86">
<F>8441856</F>
</Row>
<Row index="87">
<F>8335360</F>
</Row>
<Row index="88">
<F>7905280</F>
</Row>
<Row index="89">
<F>7450624</F>
</Row>
<Row index="90">
<F>7323648</F>
</Row>
<Row index="91">
<F>6950912</F>
</Row>
<Row index="92">
<F>6631424</F>
</Row>
<Row index="93">
<F>6242304</F>
</Row>
<Row index="94">
<F>5861376</F>
</Row>
<Row index="95">
<F>5779456</F>
</Row>
<Row index="96">
<F>5201920</F>
</Row>
<Row index="97">
<F>5087232</F>
</Row>
<Row index="98">
<F>5079040</F>
</Row>
<Row index="99">
<F>5033984</F>
</Row>
<Row index="100">
<F>4837376</F>
</Row>
<Row index="101">
<F>4726784</F>
</Row>
<Row index="102">
<F>4141056</F>
</Row>
<Row index="103">
<F>4386816</F>
</Row>
<Row index="104">
<F>3911680</F>
</Row>
<Row index="105">
<F>3944448</F>
</Row>
<Row index="106">
<F>3661824</F>
</Row>
<Row index="107">
<F>3510272</F>
</Row>
<Row index="108">
<F>3592192</F>
</Row>
<Row index="109">
<F>3375104</F>
</Row>
<Row index="110">
<F>3100672</F>
</Row>
<Row index="111">
<F>3072000</F>
</Row>
<Row index="112">
<F>3018752</F>
</Row>
<Row index="113">
<F>3059712</F>
</Row>
<Row index="114">
<F>2584576</F>
</Row>
<Row index="115">
<F>2666496</F>
</Row>
<Row index="116">
<F>2510848</F>
</Row>
<Row index="117">
<F>2371584</F>
</Row>
<Row index="118">
<F>2469888</F>
</Row>
<Row index="119">
<F>2351104</F>
</Row>
<Row index="120">
<F>2244608</F>
</Row>
<Row index="121">
<F>2170880</F>
</Row>
<Row index="122">
<F>2093056</F>
</Row>
<Row index="123">
<F>2121728</F>
</Row>
<Row index="124">
<F>1896448</F>
</Row>
<Row index="125">
<F>1830912</F>
</Row>
<Row index="126">
<F>1794048</F>
</Row>
<Row index="127">
<F>1679360</F>
</Row>
<Row index="128">
<F>1548288</F>
</Row>
<Row index="129">
<F>1581056</F>
</Row>
<Row index="130">
<F>1536000</F>
</Row>
<Row index="131">
<F>1384448</F>
</Row>
<Row index="132">
<F>1359872</F>
</Row>
<Row index="133">
<F>1335296</F>
</Row>
<Row index="134">
<F>1331200</F>
</Row>
<Row index="135">
<F>1081344</F>
</Row>
<Row index="136">
<F>1159168</F>
</Row>
<Row index="137">
<F>1097728</F>
</Row>
<Row index="138">
<F>999424</F>
</Row>
<Row index="139">
<F>1130496</F>
</Row>
<Row index="140">
<F>1032192</F>
</Row>
<Row index="141">
<F>974848</F>
</Row>
<Row index="142">
<F>921600</F>
</Row>
<Row index="143">
<F>913408</F>
</Row>
<Row index="144">
<F>868352</F>
</Row>
<Row index="145">
<F>851968</F>
</Row>
<Row index="146">
<F>729088</F>
</Row>
<Row index="147">
<F>679936</F>
</Row>
<Row index="148">
<F>655360</F>
</Row>
<Row index="149">
<F>651264</F>
</Row>
<Row index="150">
<F>655360</F>
</Row>
<Row index="151">
<F>696320</F>
</Row>
<Row index="152">
<F>643072</F>
</Row>
<Row index="153">
<F>528384</F>
</Row>
<Row index="154">
<F>614400</F>
</Row>
<Row index="155">
<F>516096</F>
</Row>
<Row index="156">
<F>491520</F>
</Row>
<Row index="157">
<F>557056</F>
</Row>
<Row index="158">
<F>483328</F>
</Row>
<Row index="159">
<F>413696</F>
</Row>
<Row index="160">
<F>425984</F>
</Row>
<Row index="161">
<F>385024</F>
</Row>
<Row index="162">
<F>372736</F>
</Row>
<Row index="163">
<F>352256</F>
</Row>
<Row index="164">
<F>385024</F>
</Row>
<Row index="165">
<F>335872</F>
</Row>
<Row index="166">
<F>270336</F>
</Row>
<Row index="167">
<F>258048</F>
</Row>
<Row index="168">
<F>225280</F>
</Row>
<Row index="169">
<F>274432</F>
</Row>
<Row index="170">
<F>266240</F>
</Row>
<Row index="171">
<F>237568</F>
</Row>
<Row index="172">
<F>266240</F>
</Row>
<Row index="173">
<F>180224</F>
</Row>
<Row index="174">
<F>212992</F>
</Row>
<Row index="175">
<F>241664</F>
</Row>
<Row index="176">
<F>208896</F>
</Row>
<Row index="177">
<F>229376</F>
</Row>
<Row index="178">
<F>172032</F>
</Row>
<Row index="179">
<F>143360</F>
</Row>
<Row index="180">
<F>180224</F>
</Row>
<Row index="181">
<F>176128</F>
</Row>
<Row index="182">
<F>143360</F>
</Row>
<Row index="183">
<F>155648</F>
</Row>
<Row index="184">
<F>135168</F>
</Row>
<Row index="185">
<F>143360</F>
</Row>
<Row index="186">
<F>106496</F>
</Row>
<Row index="187">
<F>139264</F>
</Row>
<Row index="188">
<F>135168</F>
</Row>
<Row index="189">
<F>131072</F>
</Row>
<Row index="190">
<F>94208</F>
</Row>
<Row index="191">
<F>73728</F>
</Row>
<Row index="192">
<F>53248</F>
</Row>
<Row index="193">
<F>69632</F>
</Row>
<Row index="194">
<F>53248</F>
</Row>
<Row index="195">
<F>28672</F>
</Row>
<Row index="196">
<F>20480</F>
</Row>
<Row index="197">
<F>40960</F>
</Row>
<Row index="198">
<F>57344</F>
</Row>
<Row index="199">
<F>61440</F>
</Row>
<Row index="200">
<F>28672</F>
</Row>
<Row index="201">
<F>24576</F>
</Row>
<Row index="202">
<F>57344</F>
</Row>
<Row index="203">
<F>61440</F>
</Row>
<Row index="204">
<F>49152</F>
</Row>
<Row index="205">
<F>40960</F>
</Row>
<Row index="206">
<F>40960</F>
</Row>
<Row index="207">
<F>53248</F>
</Row>
<Row index="208">
<F>49152</F>
</Row>
<Row index="209">
<F>36864</F>
</Row>
<Row index="210">
<F>16384</F>
</Row>
<Row index="211">
<F>4096</F>
</Row>
<Row index="212">
<F>8192</F>
</Row>
<Row index="213">
<F>12288</F>
</Row>
<Row index="214">
<F>12288</F>
</Row>
<Row index="215">
<F>36864</F>
</Row>
<Row index="216">
<F>16384</F>
</Row>
<Row index="217">
<F>20480</F>
</Row>
<Row index="218">
<F>12288</F>
</Row>
<Row index="219">
<F>12288</F>
</Row>
<Row index="220">
<F>16384</F>
</Row>
<Row index="221">
<F>16384</F>
</Row>
<Row index="222">
<F>8192</F>
</Row>
<Row index="223">
<F>4096</F>
</Row>
<Row index="224">
<F>12288</F>
</Row>
<Row index="225">
<F>0</F>
</Row>
<Row index="226">
<F>4096</F>
</Row>
<Row index="227">
<F>12288</F>
</Row>
<Row index="228">
<F>0</F>
</Row>
<Row index="229">
<F>8192</F>
</Row>
<Row index="230">
<F>12288</F>
</Row>
<Row index="231">
<F>4096</F>
</Row>
<Row index="232">
<F>4096</F>
</Row>
<Row index="233">
<F>4096</F>
</Row>
<Row index="234">
<F>4096</F>
</Row>
<Row index="235">
<F>16384</F>
</Row>
<Row index="236">
<F>0</F>
</Row>
<Row index="237">
<F>0</F>
</Row>
<Row index="238">
<F>0</F>
</Row>
<Row index="239">
<F>0</F>
</Row>
<Row index="240">
<F>4096</F>
</Row>
<Row index="241">
<F>12288</F>
</Row>
<Row index="242">
<F>4096</F>
</Row>
<Row index="243">
<F>0</F>
</Row>
<Row index="244">
<F>4096</F>
</Row>
<Row index="245">
<F>0</F>
</Row>
<Row index="246">
<F>0</F>
</Row>
<Row index="247">
<F>0</F>
</Row>
<Row index="248">
<F>0</F>
</Row>
<Row index="249">
<F>8192</F>
</Row>
-----Original Message-----
From: simboss1@anonymised.com [mailto:simboss1@anonymised.com] On Behalf Of Simone
Giannecchini
Sent: Thursday, June 25, 2009 11:13 AM
To: Dale MacDonald
Subject: Re: [Geoserver-users] MrSID mosaics
Ciao Dale,
can you grab the latest nightly build from here
http://gridlock.openplans.org/geoserver/1.7.x/
and give it a try with method 1a?
Moreover, can you give some more info about the structure of your data
(like a gdalinfo output on one of your dataset) just to get a feeling
about why you are getting this error?
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Thu, Jun 25, 2009 at 6:05 PM, Dale MacDonald<mrdale@anonymised.com> wrote:
I'm having three problems with MrSID mosaics in 1.7.5 Individual MrSID
files work fine but once I try to mosaic them everything goes pear-shaped.
1a) If I use the old shapefile+prj+prpertiesmethod (with the addition of
AbsolutePath=true in the properties file) I get all black images and lo
and
behold the log file indicates that I'm still getting relative paths to my
imagery (which spans several disks)
Error message =
INFO | jvm 2 | 2009/06/25 08:52:05 | 25 Jun 08:52:05 INFO
[gce.imagemosai] - Unable to read image for file
e:\data_dir\coverages\NAIP\j:\imagery\NAIP\MAINe_06\naip_1-1_2n_s_me019_2006
_1.sid
properties file =
Name=Maine_06
Levels=2.000000000000000,2.000000000000000
LevelsNum=1
Envelope2D=334334.000000,4768732.000000 663392.000000,5247514.000000
NumFiles=16
AbsolutePath=true
1b) If I use the old method and the imagery is in a place where the
relative
path will work I get rendering errors (see stack trace below)
2) If I use the new method of just pointing the coverage store at a folder
it runs at a glacial pace and doesn't seem to thread terribly well. I'm
running on a 2.6GHz i7 processor and it takes more than 30 minutes to
render
the top layer of the pyramid for a mosaic that is only 16 files. Only one
thread seems to get devoted to rendering a requested mosaic.
Dale.
INFO | jvm 2 | 2009/06/25 07:42:31 | 25 Jun 07:42:31 ERROR
[geotools.rendering] - This affine transform is unmodifiable.
java.lang.UnsupportedOperationException: This affine transform is
unmodifiable.
INFO | jvm 2 | 2009/06/25 07:42:31 | at
org.geotools.referencing.operation.matrix.XAffineTransform.checkPermission(X
AffineTransform.java:87)
org.geotools.referencing.operation.transform.AffineTransform2D.checkPermissi
on(AffineTransform2D.java:92)
org.geotools.referencing.operation.matrix.XAffineTransform.preConcatenate(XA
ffineTransform.java:224)
org.geotools.gce.imagemosaic.RasterLayerRequest.inspectCoordinateReferenceSy
stems(RasterLayerRequest.java:398)
org.geotools.gce.imagemosaic.RasterLayerRequest.computeRequestSpatialElement
s(RasterLayerRequest.java:588)
org.geotools.gce.imagemosaic.RasterLayerRequest.prepare(RasterLayerRequest.j
ava:361)
org.geotools.gce.imagemosaic.RasterLayerRequest.<init>(RasterLayerRequest.ja
va:170)
org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:616)
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:3
95)
org.geotools.renderer.lite.StreamingRenderer.renderRaster(StreamingRenderer.
java:2026)
org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRen
derer.java:1910)
org.geotools.renderer.lite.StreamingRenderer.process(StreamingRenderer.java:
1856)
org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer
.java:1798)
org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRendere
r.java:1713)
org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:66
1)
org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(Sh
apefileRenderer.java:1492)
org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1
346)
org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:2
67)
org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(Default
RasterMapProducer.java:405)
org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:
416)
org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:
48)
org.geoserver.ows.Dispatcher.response(Dispatcher.java:699)
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abstrac
tController.java:153)
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(Si
mpleControllerHandlerAdapter.java:48)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServl
et.java:875)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServle
t.java:809)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkSer
vlet.java:571)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java
:501)
javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler
.java:1093)
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterE
ncodingFilter.java:108)
.java:1084)
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterCh
ainProxy.java:265)
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecur
ityInterceptor.java:107)
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSec
urityInterceptor.java:72)
ainProxy.java:275)
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslatio
nFilter.java:124)
ainProxy.java:275)
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(Ano
nymousProcessingFilter.java:125)
ainProxy.java:275)
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessin
gFilter.java:174)
ainProxy.java:275)
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpS
essionContextIntegrationFilter.java:249)
ainProxy.java:275)
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
.java:1084)
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
.java:1084)
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:16
3)
.java:1084)
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
.java:1084)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerColl
ection.java:206)
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:11
4)
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
org.mortbay.jetty.Server.handle(Server.java:324)
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnectio
n.java:828)
org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:4
50)
INFO | jvm 2 | 2009/06/25 07:42:31 | 25 Jun 07:42:31 DEBUG [wms.map]
Rendering error occurred
INFO | jvm 2 | 2009/06/25 07:42:31 | java.lang.Exception: Error
rendering feature
.java:1803)
r.java:1713)
1)
346)
67)
416)
48)
et.java:875)
t.java:809)
vlet.java:571)
:501)
.java:1093)
.java:1084)
ainProxy.java:265)
ainProxy.java:275)
nFilter.java:124)
ainProxy.java:275)
ainProxy.java:275)
gFilter.java:174)
ainProxy.java:275)
ainProxy.java:275)
.java:1084)
.java:1084)
3)
.java:1084)
.java:1084)
ection.java:206)
4)
n.java:828)
50)
INFO | jvm 2 | 2009/06/25 07:42:31 | Caused by:
unmodifiable.
ava:361)
va:170)
95)
java:2026)
derer.java:1910)
1856)
.java:1798)
INFO | jvm 2 | 2009/06/25 07:42:31 | ... 59 more
Geoserver-users mailing list
Checked by AVG - www.avg.com
Version: 8.5.375 / Virus Database: 270.12.90/2200 - Release Date: 06/25/09
06:22:00
