I’m trying to get GeoServer to serve MrSID images with no success. I have installed the GDAL libraries and data correctly using the steps provided in the User Documentation (all x64) and the standard GDAL formats do show up as available in GeoServer, however when I install the library for MrSID support using the .msi (gdal-19-1600-x64-mrsid.msi) the MrSID format does not display as available in GeoServer and running the /javainfo/gdalinfo.bat file does not show MrSID as a supported format, but when i just run the gdalinfo.exe it does show as an available format. What do I need to do to get the java environment to see the MrSID format?
SETUP:
Win7 x64
Java JRE 7u25 x64
GeoServer Version 2.3.3
GEOSERVER_HOME = C:\Program Files\GeoServer
GEOSERVER_DATA_DIR=C:\MapData
GDAL_DATA=C:\Program Files\GDAL\gdal_data
PATH=…;C:\Program Files\GDAL\gdal_1.9.2;C:\Program Files\GDAL\gdal_1.9.2\gdalplugins
Ben
I believe you are missing GDAL_DRIVER_PATH env var (I notice the doc
needs to be improved, I'll do that on Monday).
Long story short:
- put the dlls for MrSID in a specific fir
- create an env var called GDAL_DRIVER_PATH and make it point to the
previous dir
- restart and cross fingers
Notice for other readers, this is neede _only_ on our builds for
windows. More info here:
http://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_DRIVER_PATH
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Jul 18, 2013 at 4:37 PM, Ben Johnson <weagle08@anonymised.com> wrote:
I'm trying to get GeoServer to serve MrSID images with no success. I have
SETUP:
Win7 x64
Java JRE 7u25 x64
PATH=...;C:\Program Files\GDAL\gdal_1.9.2;C:\Program
Ben
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
