[Geoserver-users] MrSID not being seen by GeoServer
This solution worked!
Thanks!
Ben
Sent from my Windows Phone From: Simone Giannecchini
Sent: 7/18/2013 11:46 AM
To: Ben Johnson
Subject: Re: [Geoserver-users] MrSID not being seen by GeoServer
I believe you are missing GDAL_DRIVER_PATH env var (I notice the doc
needs to be improved, I'll do that on Monday).
Long story short:
- put the dlls for MrSID in a specific fir
- create an env var called GDAL_DRIVER_PATH and make it point to the
previous dir
- restart and cross fingers
Notice for other readers, this is neede _only_ on our builds for
windows. More info here:
http://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_DRIVER_PATH
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Jul 18, 2013 at 4:37 PM, Ben Johnson <weagle08@anonymised.com> wrote:
I'm trying to get GeoServer to serve MrSID images with no success. I have
installed the GDAL libraries and data correctly using the steps provided in
the User Documentation (all x64) and the standard GDAL formats do show up as
available in GeoServer, however when I install the library for MrSID support
using the .msi (gdal-19-1600-x64-mrsid.msi) the MrSID format does not
display as available in GeoServer and running the /javainfo/gdalinfo.bat
file does not show MrSID as a supported format, but when i just run the
gdalinfo.exe it does show as an available format. What do I need to do to
get the java environment to see the MrSID format?
SETUP:
Win7 x64
Java JRE 7u25 x64
GeoServer Version 2.3.3
GEOSERVER_HOME = C:\Program Files\GeoServer
GEOSERVER_DATA_DIR=C:\MapData
GDAL_DATA=C:\Program Files\GDAL\gdal_data
PATH=...;C:\Program Files\GDAL\gdal_1.9.2;C:\Program
Files\GDAL\gdal_1.9.2\gdalplugins
Ben
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
