Since you have built GDAL 1.10dev on your system, you could also try building 1.9.2 (which is the one used by ImageIO-Ext 1.1.6) so that you will be sure to use the system libraries (GLIBC…) you have available on your system.
(Make sure to use the --with-threads config option when configuring the build).
Hope this helps.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Tue, Jun 11, 2013 at 10:49 PM, Gavin Fleming <gavin@anonymised.com> wrote:
Hi Daniele
No, if I force LD_LIBRARY_PATH I get quite different output and another error:
gavin@anonymised.com:~$ export LD_LIBRARY_PATH=“/usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/”
gavin@anonymised.com:~$ ldd /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/gdalinfo
/usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/gdalinfo: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14’ not found (required by /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libNCSEcw.so.0)
linux-vdso.so.1 => (0x00007fff64be1000)
libgdal.so.1 => /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libgdal.so.1 (0x00007feec7e19000)
libNCSEcw.so.0 => /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libNCSEcw.so.0 (0x00007feec7ae5000)
libNCSEcwC.so.0 => /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libNCSEcwC.so.0 (0x00007feec78e1000)
libNCSCnet.so.0 => /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libNCSCnet.so.0 (0x00007feec76cd000)
libNCSUtil.so.0 => /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libNCSUtil.so.0 (0x00007feec74a8000)
librt.so.1 => /lib/librt.so.1 (0x00007feec7299000)
libdl.so.2 => /lib/libdl.so.2 (0x00007feec7095000)
libltidsdk.so => /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/libltidsdk.so (0x00007feec6a69000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007feec684c000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007feec6538000)
libm.so.6 => /lib/libm.so.6 (0x00007feec62b4000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007feec609d000)
libc.so.6 => /lib/libc.so.6 (0x00007feec5d17000)
/lib64/ld-linux-x86-64.so.2 (0x00007feec8898000)
On 11/06/2013 11:18, Daniele Romagnoli wrote:
Hi Gavin,
It seems you have multiple GDAL libs and third party libs available on your system (some of them are on /usr/local/lib).
Do you get this output even when forcing the LD_LIBRARY_PATH to refer to the folder where you have extracted the 1.9.2 downloaded ones?
Daniele
regards
Gavin
Gavin Fleming
[http://afrispatial.co.za](http://afrispatial.co.za)
t: 0218620670
c: 0845965680
f: 0866164820
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
On Tue, Jun 11, 2013 at 11:03 AM, Gavin Fleming <gavin@anonymised.com> wrote:
Hi Daniele
linux-vdso.so.1 => (0x00007fff1def9000)
libgdal.so.1 => /usr/local/lib/libgdal.so.1 (0x00007f70f3c67000)
libNCSEcw.so.0 => /usr/local/lib/libNCSEcw.so.0 (0x00007f70f3929000)
libNCSEcwC.so.0 => /usr/local/lib/libNCSEcwC.so.0 (0x00007f70f3724000)
libNCSCnet.so.0 => /usr/local/lib/libNCSCnet.so.0 (0x00007f70f350e000)
libNCSUtil.so.0 => /usr/local/lib/libNCSUtil.so.0 (0x00007f70f32e8000)
librt.so.1 => /lib/librt.so.1 (0x00007f70f30df000)
libdl.so.2 => /lib/libdl.so.2 (0x00007f70f2edb000)
libltidsdk.so => not found
libpthread.so.0 => /lib/libpthread.so.0 (0x00007f70f2cbd000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007f70f29a9000)
libm.so.6 => /lib/libm.so.6 (0x00007f70f2726000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007f70f250e000)
libc.so.6 => /lib/libc.so.6 (0x00007f70f2188000)
libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0x00007f70f1efb000)
libexpat.so.1 => /lib/libexpat.so.1 (0x00007f70f1cd1000)
libpq.so.5 => /usr/lib/libpq.so.5 (0x00007f70f1aa4000)
libz.so.1 => /lib/libz.so.1 (0x00007f70f188d000)
libpcre.so.3 => /lib/libpcre.so.3 (0x00007f70f165e000)
/lib64/ld-linux-x86-64.so.2 (0x00007f70f4c1e000)
libssl.so.0.9.8 => /lib/libssl.so.0.9.8 (0x00007f70f140a000)
libcrypto.so.0.9.8 => /lib/libcrypto.so.0.9.8 (0x00007f70f1078000)
libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x00007f70f0db4000)
libcom_err.so.2 => /lib/libcom_err.so.2 (0x00007f70f0bb0000)
libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0x00007f70f097b000)
libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2 (0x00007f70f072f000)
libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x00007f70f0508000)
libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0x00007f70f0300000)
libkeyutils.so.1 => /lib/libkeyutils.so.1 (0x00007f70f00fd000)
libresolv.so.2 => /lib/libresolv.so.2 (0x00007f70efee4000)
liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0x00007f70efcd5000)
libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0x00007f70efabb000)
libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0x00007f70ef819000)
libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0x00007f70ef607000)
libgcrypt.so.11 => /lib/libgcrypt.so.11 (0x00007f70ef38f000)
libgpg-error.so.0 => /lib/libgpg-error.so.0 (0x00007f70ef18b000)
On 11/06/2013 09:34, Daniele Romagnoli wrote:
Hi Gavin,
please read below…
regards
Gavin
Gavin Fleming
t: 0218620670
c: 0845965680
f: 0866164820
On Mon, Jun 10, 2013 at 1:53 PM, Gavin Fleming <gavin@anonymised.com> wrote:
Hi Daniele
Ubuntu server 10.04 LTS
Geoserver 2.2.4
Tomcat 6
From http://geoserver.org/display/GEOS/GeoServer+2.2.4:
GDAL extension: geoserver-2.2.4-gdal-plugin.zip
→ extracted to /var/lib/tomcat6/webapps/geoserver/WEB-INF/lib/
From http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.6/:
GDAL native libs: gdal192-Ubuntu11-gcc4.5.2-x86_64.tar.gz
→ extracted to /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/
/usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/gdalinfo --version
/usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/gdalinfo: error while loading shared libraries: libltidsdk.so: cannot open shared object file: No such file or directory
I’m wondering whether that gcc version build is supported on your 10.04…
Can you try a “ldd /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/amd64/gdalinfo” and check the output?
(I’ve also tried the previous one, gdal1.7.3-linux64-base-gcc43.tar.gz. That doesn’t work either, but didn’t give the libltidsdk.so error.)
It requires a different gdal-bindings jar (the one made for 1.7.3 version) whilst you are trying to use 1.9.2-bindings against 1.7.3 native libs.
ImageIO-Ext version: from imageio-ext-1.1.6-jars.zip
gdal-data.zip → extracted to /usr/local/gdal_data
/etc/environment:
GDAL_DATA=“/usr/local/gdal_data”
System GDAL: GDAL 1.10dev (compiled from source to add mrsid and ecw). cli gdal utilies work fine with mrsids. e.g. gdal_retile.py built a pyramid from mrsids no problem.
thanks in advance
Gavin
Please, let us know.
Daniele
On 10/06/2013 10:03, Daniele Romagnoli wrote:
Hi Gavin,
can you please provide us some more details on your system?
Which OS are you using?
Which Set of GDAL extensions, ImageIO-EXT version and GDAL native libs are you using?
Daniele
regards
Gavin
Gavin Fleming
t: 0218620670
c: 0845965680
f: 0866164820
On Sat, Jun 8, 2013 at 2:59 PM, Gavin Fleming <gavin@anonymised.com> wrote:
Hi
I can see all the GDAL raster types and can complete the form for
creation of a MrSID or ECW store. However, when I Save, the screen
doesn’t revert to the Publish screen, yet no errors are returned. I have
to click Cancel. Nevertheless, the store does appear in the list of
stores, yet I cannot create a layer from it. Even on verbose, there’s
nothing obvious in the logs.
Geoserver 2.2.4
Any known issues with this version of Geoserver? I’d appreciate any tips.
I really need to get this working so I can use the MrSIDs as level 0 of
an Image pyramid layer and geotiffs generated by gdal_retile as the
pyramid layers, thus avoiding having to generate a massive level 0 of
geotiffs.
thanks in advance
Gavin
How ServiceNow helps IT people transform IT departments:
- A cloud service to automate IT design, transition and operations
- Dashboards that offer high-level views of enterprise services
- A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
Geoserver-users mailing list
Geoserver-users@anonymised.comge.net
