[Geoserver-users] MSSQL 2014?
Does Geoserver support MS SQL 2014?
/Per Söderström, GIS, Kungsbacka kommun
On Mon, Nov 10, 2014 at 11:59 AM, Per Söderström <
per.soderstrom@anonymised.com> wrote:
The sql server stores has been developed and tested against ms sql 2008,
but if Microsoft
hasn't made incompatible changes, it should work with newer versions too.
Why don't you try it out, and let us know if it works with version 2014, or
not?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
