Hi all. ECW install instructions [1] state to go here [2] to install the native libraries for Windows.
But I see that the options stop at MSVC2010. Is there a MSVC2012 option? The target platform is MS Server 2012 (x64) and the 2010 option doesn't seem to work.
[1] http://docs.geoserver.org/latest/en/user/data/raster/gdal.html
[2] http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.13/native/gdal/windows/
Mike
Mike Pumphrey
User Advocate | Boundless
917-338-0407
mike@anonymised.com
http://boundlessgeo.com
@boundlessgeo
Hi Mike,
there is no MSVC2012 option. Those versions are based on the one available on GISInternals releases: http://www.gisinternals.com/archive.php
It seems like MSVC2010 doesn’t support Windows Server 2012.
https://www.microsoft.com/en-US/download/details.aspx?id=14632
Although we never personally did tests with higher GDAL versions, there are several emails on the list about users experimenting GDAL 1.11 on GeoServer.
I don’t remember the outcome of their tests but if they had those versions working, you may consider testing them on your side too.
In that case, the GISInternals page contains GDAL 1.11.4 native libs for MSVC2012 and MSVC2013.
http://www.gisinternals.com/release.php
Again, I’m not sure if at the end they will work OR if you need to do some tuning on your side since we never tested them.
However it can be a path to try to get something working on MS Server 2012.
Hope this helps.
Daniele
The target platform is MS Server 2012 (x64) and the 2010 option doesn’t
seem to work.
[2]
Mike
Mike Pumphrey
917-338-0407
mike@anonymised.com
@boundlessgeo
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Dear all,
we have troubles in cascading a WMS layer for the OSM of Italy, it is served as basemap to another server’s layer that is used for generating dynamic PDFs.
The architecture is made on two servers (both on Geoserver 2.6.2):
- SERVER-A, is the map server to publish our replica of the Italian OSM. It works on top of a PostGIS that is synced periodically with OSM planet and it uses styles for points, polygons and lines.
- SERVER-B, is the map server we provided our client; it uses the WMS rendered by SERVER-A as base layer for another WMS services used for PDF generation.
Server A and B are in the same network on Digital Ocean. Moving the access to the data and the rendering to the SERVER-B is not an option for now.
We have two kinds of problems, we do not know whether they are related or not:
- SERVER-B Tomcat crashes periodically, so far we were not able to find any message in the catalpa.out log. We are not sure it is the right place to check as we are not experts of Tomcat.
- SERVER-A becomes very slow; when this happens the direct calls to WMS done through the SERVER-B and SERVER-A are still working, but the Geoserver admin panel cannot use or preview the SERVER-A basemap, the exception says that the underlying service does not exists.
We wonder whether there is some specific documentation, or somebody can give hints about tracking the errors.
More, we are sure the servers are under-dimensioned. Is there any specific reference to dimensioning and performance optimization on geoserver? Anybody with a similar experience? In your experience should the server chaining the WMS and overlaying few points to it be dimensioned similar to the server doing the OSM rendering?
Thanks for any help.
Simone
Smart technologies for bright ideas
Simone Gadenz
CEO
Mobile: +39 331 72 35 993
Office: +39 0577 588 408
Web: http://www.beecome.it
