[Geoserver-users] multi-tenant or farm hosting
we’re looking into reducing the number of geoserver instances in our network. We currently have a geoserver for each client/project in a virtual host, but for reasons of resource utilisation and maintenance we would like to concentrate multiple (smaller) clients/projects on one geoserver with one workspace each.
The catch here is that a client/project admin should not see any of the other client/project workspaces, datasources, services, layers etc. A global admin should be able to manage all and I think it should be possible to restrict a client/project admin to a workspace, but it seems impossible to hide away other workspaces, datasources, styles etc.
Is this assumption correct?
Thanx, Mark
Disclaimer;
This message is just a reflection of what I thought at the time of sending. The message may contain information that is not intended for you or that you don’t understand.
On Thu, Jun 16, 2016 at 12:47 PM, Mark Prins <mc.prins@anonymised.com> wrote:
we're looking into reducing the number of geoserver instances in our
one workspace each.
The catch here is that a client/project admin should not _see_ any of the
You can create users and give them admin right on specific workspaces using
the data security subsystem.
See here, the examples use the file syntax instead of showing the GUI, but
it's the same:
http://docs.geoserver.org/stable/en/user/security/layer.html#providing-restricted-administrative-access
Mind there are limitations, in particular, GWC does not work well with per
workspace services (Nuno is working on
fixing that btw, just at the integration level, not trying to add the
workspace concept way down in GWC, that would
require too much work).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
