I'm working on exposing a single EO dataset in geoserver through the WCS-EO
and WMS-EO services. The dataset consists of multiple bands, but they are
exposed through a custom dimension of the underlying image mosaic.
This works very well for WMS-EO, but doesn't seem to work for WCS.
Does know how such a setup can be made to work? The underlying image format is
NetCDF4, so the bands in the data are in fact separate netcdf variables.
thanks,
Jeroen
VITO Disclaimer: http://www.vito.be/e-maildisclaimer
On Thu, Jan 23, 2014 at 10:33 AM, Dries Jeroen <jeroen.dries@anonymised.com> wrote:
format is
Not sure... in our case we prepare the data and have different versions of
it published
as WMS-EO, and as WCS, because as you said the needs of the two protocols
are different.
I guess it would be interesting if the bands dimension was active only when
certain request
params are used, or something like that.
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
see inline
it published
are different.
Is there any guidance to be found on how to prepare a netcdf dataset
consisting of multiple files so that the variables in those files show up as
bands of a single coverage? (To support WCS)
certain request
I may be able to do that already, but even then I still need to somehow expose
multiple bands in my mosaic.
thanks,
Jeroen
Op 23/01/2014 11:28, Dries Jeroen schreef:
see inline
it published
are different.
We implemented this by transforming the original files to geoTiff multiband files.
This was the most performant way for displaying large coverage files and accessing them.
For the rest we found no specific userguide to help us.
certain request
thanks,
Jeroen
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Eric Smets eric.smets@anonymised.com
FKS bvba - Formal and Knowledge Systems http://www.fks.be/
Schampbergstraat 32 Tel: ++32-(0)11-21 49 11
B-3511 Hasselt Fax: ++32-(0)11-22 04 19
thanks for the suggestion, but in this specific project we would like to avoid
copying the entire dataset. We try to achieve performance by using
geowebcache.
However, the fact that WMS-EO can use jai to combine multiple granules into a
single image, seems to suggest that exactly the same thing should be possible
for WCS, but it just isn't implemented right now.
Is anyone else interested in this kind of implementation, which would enable
the use of the same data source for both WMS and WCS?
thanks,
Jeroen
> Hi,
> see inline
>> of
>> it published
>> are different.
> as bands of a single coverage? (To support WCS)
files. This was the most performant way for displaying large coverage files
and accessing them.
>> when
>> certain request
> expose multiple bands in my mosaic.
>> Cheers
>> Andrea
> thanks,
> Jeroen
> ---- CenturyLink Cloud: The Leader in Enterprise Cloud Services.
> rk _______________________________________________
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
