hi, is it possible to define multiple different FeatureType's off the same
PostGIS table? if I have a layer based on, say, census_tracts and then go
to make a New FeatureType based on the same table, it just overrides the old
one.
I want to do this because I want to have a number of different labeling
options for one data set that I can access thru WMS requests.
thanks,
mike
View this message in context: http://www.nabble.com/multiple-FeatureType's-off-the-same-PostGIS-table-tf3697453.html#a10339483
I believe if you define a new datastore for each new featureType then you can do it. And to get it to work properly you'll need to define different namespaces for each datastore, so they don't conflict. If that doesn't work then it's a bug. I realize this is less than ideal, but it's all we've got until we're able to map a featureType to a different name, or else you'll get conflicts.
But if you're just wanting to make different labeling options you can just define more SLD files, and then in the FeatureType editor select them as non-default ones. You shouldn't need to define more than one featureType just to have them labeled differently. But the client will need to know to request the different styles.
Chris
one.
thanks,
mike
Chris Holmes
The Open Planning Project
http://topp.openplans.org
I don't know much about PostGIS, but how about making a bunch of views with unique names inside database and then FeatureTypes from those? Or does this ruin the effect of spatial index or something? I have made a simple trial with this in Oracle and it worked there.
-Jukka Rahkonen-
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net on behalf of Chris Holmes
Sent: Sat 5.5.2007 22:47
To: mfrumin
Subject: Re: [Geoserver-users] multiple FeatureType's off the same PostGIS table
Chris
one.
thanks,
mike
Chris Holmes
