is it possible to specify the geometry attribute when configuring a
Postgis datastore in Geoserver ?
Christophe
Christophe
Hi Christophe,
Not really... What is your use case? Do you have a postgis table with
multiple geometry columns in it?
Christophe ROUSSON wrote:
Postgis datastore in Geoserver ?Thanks,
Christophe
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,478796b8235166491211187!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin Deoliveira a écrit :
Hi Christophe,
Exactly, I have a feature table with multiple representations.
Geoserver seems to pick the first geometry column it sees.
As a workaround, I could define a view for each representation with only one geometry.
Christophe
Hi Christophe,
Hum, GeoServer picks the first geometry as the default geometry, yes,
but the others should be available as well. If you do a WFS GetFeature
request you should see them all. If you need to use a geometry other
than the default one in WMS you can do so by specifying the geometry
column in the symbolizer, for example:
<LineSymbolizer>
<Geometry>
<ogc:PropertyName>mySecondaryGeomColumn</ogc:PropertyName>
</Geometry>
<Stroke>
<CssParameter name="stroke">#B9AE9B</CssParameter>
<CssParameter name="stroke-width">3</CssParameter>
</Stroke>
</LineSymbolizer>
Hope this helps
Hi Christophe,
As a workaround, I could define a view for each representation with only one geometry.Hum, GeoServer picks the first geometry as the default geometry, yes,
column in the symbolizer, for example:<LineSymbolizer>
<Geometry>
</Geometry>
<Stroke>
</Stroke>
</LineSymbolizer>Hope this helps
Cool, it does work really well.
But is there some doc about the geoserver xml config files structure ?
I found http://docs.codehaus.org/display/GEOSDOC/2+Files
but it looks like examples, rather than doc.
Thanks.
Christophe
Hope this helps
There are no docs because you're not supposed to manually alter them.
All sort of crashes may happen if you do so.
