Here is the WFS GetFeature dump of the multilinestring in question.
<gml:MultiLineString srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:lineStringMember>
<gml:LineString>
<gml:coordinates decimal="." cs="," ts=" ">
-80.19981076,37.23097372 -80.19887208,37.23137369 -80.19871719,37.23143066 -80.19856308,37.23149756 -80.1984083,37.23156403 -80.19825479,37.23163099 -80.1980991,37.23169726 -80.19794271,37.23176416 -80.19778505,37.23183198 -80.19762624,37.23189889 -80.19746841,37.23196756 -80.19731119,37.23203613 -80.19715396,37.23210516 -80.19697841,37.23218285
</gml:coordinates>
</gml:LineString>
</gml:lineStringMember>
<gml:LineString>
-80.10983054,37.28156697 -80.10970765,37.28157587 -80.10936321,37.2816083 -80.10917963,37.28162199 -80.10899027,37.28163728 -80.10880954,37.28165169 -80.10863149,37.28166485 -80.10846232,37.28167681 -80.10829652,37.28168699 -80.10810266,37.28171344 -80.10800713,37.28172328 -80.10793363,37.28172655 -80.10777314,37.28173746
</gml:coordinates>
</gml:LineString>
</gml:MultiLineString>
Does this look OK? The SLD is:
<LineSymbolizer>
<Stroke>
<CssParameter name="stroke">#FF0000</CssParameter>
<CssParameter name="stroke-width">5</CssParameter>
<CssParameter name="stroke-opacity">1</CssParameter>
</Stroke>
</LineSymbolizer>
The second line string (I have omitted some of the coordinates) gets drawn but the first does not. Any ideas?
David
David R Robison wrote:
I am trying to render a MultiLineString feature with a SLD LineSymbolizer. However, it appears that only one of the line strings is being rendered. Any thoughts on what might be going on? Should LineSymbolizer work for a MultiLineString? One note, the multiple line strings are NOT connected.
Thanks, David Robison
David R Robison
Open Roads Consulting, Inc.
708 S. Battlefield Blvd., Chesapeake, VA 23322
phone: (757) 546-3401
e-mail: drrobison@anonymised.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
This e-mail communication (including any attachments) may contain confidential and/or privileged material intended solely for the individual or entity to which it is addressed. If you are not the intended recipient, you should immediately stop reading this message and delete it from all computers that it resides on. Any unauthorized reading, distribution, copying or other use of this communication (or its attachments) is strictly prohibited. If you have received this communication in error, please notify us immediately.
