hi ,
i am using one shape file to build map… now i want to add layers to the map (shapefile)… how should i do that please let me know the detialed steps to do that.
thanks
Naseer MCA
hi ,
thanks
Naseer MCA
Naseer Mohammed Abdul ha scritto:
hi ,
i am using one shape file to build map... now i want to add layers to the map (shapefile).. how should i do that please let me know the detialed steps to do that.
Hem, detailed steps, I dont' have time to provide. But anyways,
you have to configure each shape file in the data configuration
section just like you did with the first, and then issue wms
requests that do use more than one layer.
See the WMS 1.1.1 standard if you are doing direct request (www.opengeospatial.org), or your client documentation if you are using a javascript client such as MapBuilder or OpenLayers.
IHi Naseer,
When you make a WMS request there are two parameters: "layers=" and "styles="
To have geoserver render multiple layers (shapefiles) just append the layer names and their styles to the request. For example:
layers=topp:states,topp:mylayer,ggg:mylayer2&styles=population,mystyle1,mystyle2
Brent Owens
(The Open Planning Project)
hi ,
requests that do use more than one layer.See the WMS 1.1.1 standard if you are doing direct request (www.opengeospatial.org), or your client documentation if you are using a javascript client such as MapBuilder or OpenLayers.
Andrea-------------------------------------------------------------------------
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
