On Fri, Sep 25, 2015 at 6:48 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
It looks like GetLegendGraphic only supports requesting a legend for a
single layer. Could this be generalized to allow multiple layers being
requested?
Hi Martin,
sorry for chiming in late. The GetLegendGraphic internal code already
supports a list of layers, this feature has been added by Mauro
almost two years ago when adding supporting layer groups in
GetLegendGraphic (which is, as usual, exploded in its internal list
of layers at parsing time).
What is missing, as far as I can see, is just the code that would parse a
comma separate list of layers/styles in the request, as far as I know
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
