[Geoserver-users] Multiple Layers in WMS GetFeatureInfo Requests
When a WMS GetFeatureInfo request contains multiple layers or layer groups
where at least one is queryable and one is not queryable, it appears that
the filtering of the non-queryable layers and layer groups can cause the
styles and cql_filter parameters to get mixed up. This can cause service
exceptions or incorrect responses. For example, a styles mixup can cause an
error that says "The requested Style can not be used with this layer." and a
cql_filter mixup can cause an INCLUDE filter to be used instead of the
requested filter.
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/Multiple-Layers-in-WMS-GetFeatureInfo-Requests-tp5317231.html
I believe this has been fixed recently? At least for the style part, did not check the filters:
https://osgeo-org.atlassian.net/browse/GEOS-8005
On Thu, Apr 13, 2017 at 5:12 PM, sikeoka <steve.ikeoka@anonymised.com> wrote:
error that says “The requested Style can not be used with this layer.” and a
requested filter.
Steve Ikeoka
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I can't test 2.11.0 because of the Maven repo problem but I reviewed the fix
for GEOS-8005 and that appears to be an unrelated issue.
This problem happens because
org.geoserver.wms.map.GetMapKvpRequestReader.skipResource(Object) filters
out the non-queryable layers and layer groups from the WMS GetFeatureInfo
request but does not remove their corresponding styles and cql_filter or
filter.
Steve Ikeoka
View this message in context: http://osgeo-org.1560.x6.nabble.com/Multiple-Layers-in-WMS-GetFeatureInfo-Requests-tp5317231p5317239.html
ah I see, then yes, it’s a different issue
On Thu, Apr 13, 2017 at 6:03 PM, sikeoka <steve.ikeoka@anonymised.com> wrote:
I can’t test 2.11.0 because of the Maven repo problem but I reviewed the fix
filter.
Steve Ikeoka
Ing. Andrea Aime
@geowolf
Technical Lead
