Hi all
I was hoping someone might be able to advise on the best way to configure the following scenario. I have a box with GeoServer on with IIS 7.5 using ARR as a proxy. Then I have a second web box which is hosting an OL app (again IIS 7.5) that wants to send GetFeatureInfo requests to the GeoServer box, which is the part that doesn’t work (layers/legend load fine).
Do I need to use another proxy on the web box or is there something more to be done on the GeoServer box to append the web box to a trusted list? I would just like to use IIS or change some GeoServer config settings rather than use cgi etc.
Chris
