On Thu, Oct 30, 2014 at 11:30 PM, Eng'r Khalid Omar <khalid.hanafy@anonymised.com
wrote:
Hello;
I have table that store data for saudiArabia map that data use utm zone37
(32637) and Utm zone 38 (32638) can I use geoserver to host that table and
how can I configure that
Or I should transform this coordinates to wgs 84 (4326)
Note the table in sqlserver database
You can keep them in whatever coordinate system you want, but it has to be
the same for all features
in the table.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
