-----Original Message-----
Sent: vrijdag 18 april 2008 14:53
To: Veldkamp, Berend
Subject: Re: [Geoserver-users] Multiple WMS Services
Berendv ha scritto:
> Hi,
> Is it possible to serve multiple WMS services with GeoServer? Like,
> with the ArcIMS wmsconnector, I can add a "ServiceName=MyService"
> parameter to the WMS request, and with UMN MapServer I can
specify a different mapfile.
> It seems to me that GeoServer serves all specified featuretypes, or
> maybe I am missing something? It would definitely be nice
if I could
> at least specify a subset of layers.
No, GeoServer does not support that. We have talks about
adding such a support, but it will require some significant
changes in GeoServer, so that's probably something delayed
until GeoServer 2.0 (release date unknown).
For the moment, you have two options:
* if your layer set is stable, extract the capabilities once, save,
manually alter them, save again under a different name, publish
the capabilities file as a static file. Should be ok.
* otherwise, you can deploy multiple geoserver instances inside the
same web container (Tomcat or similar).
Andrea,
Thanks for your reply.
I'm not sure it will work though: Most wms clients that I know of accept a service url, and append "service=WMS&request=getcapabilities" to it. So even if I have a static capabilities document elsewhere, it won't be found. Maybe Apache's mod_rewrite could come in handy here, though.
As for you other suggestion to run multiple instances of GeoServer, I think that could work, but right now I have set the GEOSERVER_DATA_DIR environment variable so that I can have my data located outside of my container directory (JBoss). AFAIK that env var would apply to both instances of GeoServer, so they would share their configuration. I'm not sure if I can have an environment var that applies to one war only, but I'll see what I can find out.
One very simple approach (maybe too simple
would be to apply an xsl transformation to the capabilities document, so if the request contains for instance "service=myserv", then an xsl associated with that name would be applied.
Regards, Berend
<< Please read our E-mail Disclaimer at the Grontmij Corporate website >>
