[Geoserver-users] Multliple coverages in a single output NetCDF?
Does WCS 2.0.1 and (GeoServer in particular) have a mechanism to request multiple coverages in a single WCS request? NetCDF seems to be a WCS output format that could represent such a response, but I do not know if this is supported by WCS or GeoServer. I could not find anything in the WCS spec that had anything other than a single coverageid.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hi Ben,
I think that the WCS 2.0.1 GetCoverage can only returns 1 coverage. It can contain multiple dimensions subset (times, elevations, ranges,…) but only 1 coverage.
Taking a look at the specification (https://portal.opengeospatial.org/files/09-110r4) the GetCoverageRequest has a single coverageId element.
Even the GetCoverageType interface in GeoServer as a get/setCoverageId(String) method defining THE coverage id.
GetCoverageType is the input of a GetCoverage.run call producing the GridCoverage for a WCS getCoverage request.
Not sure there is any WCS extension around overcoming this limit.
Hope this helps.
Daniele
On Fri, May 20, 2016 at 2:28 AM, Ben Caradoc-Davies <ben@anonymised.com1…> wrote:
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Thanks for the confirmation, Daniele.
I think that coverage aggregation in NetCDF might be a job for WPS.
Kind regards,
Ben.
On 20/05/16 19:29, Daniele Romagnoli wrote:
Hi Ben,
contain multiple dimensions subset (times, elevations, ranges,....) but
only 1 coverage.
Hope this helps.
Daniele
On Fri, May 20, 2016 at 2:28 AM, Ben Caradoc-Davies <ben@anonymised.com>
Kind regards,
Director
New Zealand
untouched!
Director
New Zealand
On Fri, May 20, 2016 at 10:39 PM, Ben Caradoc-Davies <ben@anonymised.com>
Ah, WPS, the one protocol to rule them all :slight_smile:
(but seriously, I agree it's the only fully compliant option, the other
potential avenue being making a vendor extension to the WCS standard)
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
And in the darkness bind them. :slight_smile:
Yes, that could work. Perhaps supporting a comma-separated list of coverage IDs, and then aggregating them on output? A bit fiddly if the underlying coverages have different dimensions and coordinate variables, but it could be done. Extending WCS would mean that the method for obtaining an aggregated coverage would be very similar to the method for obtaining a single coverage.
Kind regards,
Director
New Zealand
On Sat, May 21, 2016 at 11:59 AM, Ben Caradoc-Davies <ben@anonymised.com>
Muwhaahhahahahaa!!!!
Right. To be honest, I'm not against the idea.
The major argument against would be, I guess, how can a client know if an
output format is multi-coverage capable, and what conditions do the
multi-coverages have to respect? (nothing, same CRS, same data type, and so
on?)
But to be honest, we go out with arcgrid, how does a client know that
arcgrid is not multiband capable?
Given that only a geoserver specific client would know that coverageid
might take a comma separate list of values,
the worry about output format seems moot, it seems to me the client would
have to be custom-made regardless.
The interesting part is imho another, how does one allow multi-coverage
without too deep changes in the WCS 2.0
machinery? I'd say, by having DefaultWebCoverageService20 loop over the
ids, getting a response out of each,
and then build a new multi-coverage response object that only netcdf knows
how to handle:
https://github.com/geoserver/geoserver/blob/master/src/wcs2_0/src/main/java/org/geoserver/wcs2_0/DefaultWebCoverageService20.java#L138
Ing. Andrea Aime
@geowolf
Technical Lead
how to handle:
That was what I was thinking: just loop over the coverages and then merge into a single NetCDF response on output. The least possible change to the rest of WCS 2.0.
Kind regards,
Director
New Zealand
