[Geoserver-users] Must zoom very close to show a mosaic with GS 2.6-RC1
This error happens if I have external GDAL overview files (.ovr) in the image mosaic directory. It I remove overview files the mosaic shows at all scales without errors and it I create similar overviews as internal the mosaic works again.
I have created external overviews with command
gdaladdo -ro --config COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW YCBCR image.tif 2 4 8 16 32 64
When the image mosaic is created the external overviews are obviously found because .properties file is listing them:
Levels=0.5,0.5 1.0,1.0 2.0,2.0 4.0,4.0 8.0,8.0 16.0,16.0 31.914893617021278,31.914893617021278
Problem seems to related to reading the external overviews for rendering. I guess than only internal overviews are searched.
-Jukka Rahkonen-
Nicola Lagomarsini wrote:
Hi Chris,
yes, the TIFFImageReader also affects 2.5.2 but I should investigate more deeply for checking if it is the cause of your issue. If you can provide a sample data I will try to replicate it.
Nicola Lagomarsini.
2014-09-24 17:54 GMT+02:00 Chris Snider <chris.snider@…3225…>:
Does this TIFFImageReader affect GS 2.5.2 as well?
We have been testing an image processing workflow converting MrSID files to GeoTIFF with alpha and masks being applied. When we add the overviews, we get good output until we hit at/near the “native” resolution of the GeoTiffs. At that zoom, we get the mask itself instead of the image. Zooming past the “native” resolution again shows the image with the beginnings of pixilation as expected.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...5633...
From: Nicola Lagomarsini [mailto:nicola.lagomarsini@…1107…]
Sent: Wednesday, September 24, 2014 8:11 AM
To: Andrea Aime
Cc: Rahkonen Jukka (Tike); Geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Must zoom very close to show a mosaic with GS 2.6-RC1
I noticed that the ImageMosaic is using a wrong TIFF reader (com.sun.media.imageioimpl.plugins.tiff.TIFFImageReader), which could be the cause of the issue.
I have already opened a JIRA for this: https://jira.codehaus.org/browse/GEOS-6627. I have fixed it on the master branch, it needs to be backported. Could
you try to do the same test with GeoServer master?
Nicola Lagomarsini.
2014-09-24 15:47 GMT+02:00 Andrea Aime <andrea.aime@…1107…>:
Hi Jukka,
this issue is not familar to me, and I’ve played with mosaics using a recent GS release.
Can you share just enough data to reproduce the problem?
On Wed, Sep 24, 2014 at 3:29 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@…486…> wrote:
As a side effect when trying to help Ville I noticed that if I make an image mosaic from two aerial images (6 by 6 km each) I must zoom in to about 300 by 300 m box before the map shows. The attached image show the extents of the mosaic (it is the index shapefile from the Geoserver data_dir) and with little red boxes how close I must zoom before image is shown. At smaller scales the log collects this:
2014-09-24 16:22:37,871 DEBUG [gce.imagemosaic] - We added the granule Description of a granuleDescriptor
BBOX: ReferencedEnvelope[500000.0 : 506000.0, 6834000.0 : 6840000.0]
file: file:/C:/ohjelmat/geoserver-2.6-SNAPSHOT/data_dir/coverages/aerial_images/SKM_2014_M163_TM35_M5221A.TIF
gridToWorld: PARAM_MT[“Affine”,
PARAMETER[“num_row”, 3],
PARAMETER[“num_col”, 3],
PARAMETER[“elt_0_0”, 0.5],
PARAMETER[“elt_0_2”, 500000.25],
PARAMETER[“elt_1_1”, -0.5],
PARAMETER[“elt_1_2”, 6839999.75]]
Description of level 2
Description of a granuleDescriptor level
width: 12000
height: 12000
scaleX: 1.0
scaleY: 1.0
baseToLevelTransform: PARAM_MT[“Affine”,
PARAMETER[“num_col”, 3]]
gridToWorldTransform: PARAM_MT[“Affine”,
PARAMETER[“elt_0_2”, 500000.0],
PARAMETER[“elt_1_2”, 6840000.0]]
2014-09-24 16:22:37,890 DEBUG [data.shapefile] - Read lock: file:/C:/ohjelmat/geoserver-2.6-SNAPSHOT/data_dir/coverages/aerial_images/aerial_images.shp by org.geotools.data.shapefile.shp.ShapefileReader
2014-09-24 16:22:37,891 TRACE [data.shapefile] - Shapefile Reader has been closed. Number open: 0
2014-09-24 16:22:37,891 DEBUG [data.shapefile] - Read lock: file:/C:/ohjelmat/geoserver-2.6-SNAPSHOT/data_dir/coverages/aerial_images/aerial_images.dbf by org.geotools.data.shapefile.dbf.IndexedDbaseFileReader
2014-09-24 16:22:37,891 TRACE [data.shapefile] - Dbase File Reader has been closed. Number open: 0
2014-09-24 16:22:37,892 DEBUG [data.shapefile] - Read lock: file:/C:/ohjelmat/geoserver-2.6-SNAPSHOT/data_dir/coverages/aerial_images/aerial_images.shx by org.geotools.data.shapefile.shp.IndexFile
2014-09-24 16:22:37,905 TRACE [data.shapefile] - IndexFile has been closed. Number open: 0
2014-09-24 16:22:37,905 DEBUG [gce.imagemosaic] - Producing the final mosaic, step 1, loop through granule collectors
2014-09-24 16:22:37,906 DEBUG [gce.imagemosaic] - Using collector with filter:Filter.INCLUDE
2014-09-24 16:22:37,907 INFO [gce.imagemosaic] - Adding to mosaic failed, original request was RasterLayerRequest description:
SpatialRequestHelper [requestedBBox=ReferencedEnvelope[501435.5270982131 : 502696.30819774553, 6836387.606198041 : 6837337.998922307], cropBBox=ReferencedEnvelope[501435.5270982131 : 502696.30819774553, 6836387.606198041 : 6837337.998922307], requestedRasterArea=java.awt.Rectangle[x=0,y=0,width=459,height=346], destinationRasterArea=java.awt.Rectangle[x=0,y=0,width=459,height=346], requestCRS=PROJCS[“ETRS89 / TM35FIN(E,N)”,
GEOGCS[“ETRS89”,
DATUM[“European Terrestrial Reference System 1989”,
SPHEROID[“GRS 1980”, 6378137.0, 298.257222101, AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4258”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“central_meridian”, 27.0],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“scale_factor”, 0.9996],
PARAMETER[“false_easting”, 500000.0],
PARAMETER[“false_northing”, 0.0],
UNIT[“m”, 1.0],
AXIS[“Easting”, EAST],
AXIS[“Northing”, NORTH],
AUTHORITY[“EPSG”,“3067”]], requestedGridToWorld=PARAM_MT[“Affine”,
PARAMETER[“elt_0_0”, 2.746799781116427],
PARAMETER[“elt_0_2”, 501436.90049810364],
PARAMETER[“elt_1_1”, -2.7467997811164038],
PARAMETER[“elt_1_2”, 6837336.625522416]], requestedResolution=[2.746799781116427, 2.7467997811164038], coverageProperties=org.geotools.gce.imagemosaic.SpatialRequestHelper$CoverageProperties@…6687…, accurateResolution=false, empty=false, needsReprojection=false, ]
ReadType=JAI_IMAGEREAD
2014-09-24 16:22:37,940 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:338)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:130)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:510)
at org.geoserver.wms.GetMap.run(GetMap.java:254)
at org.geoserver.wms.GetMap.run(GetMap.java:125)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:329)
at sun.reflect.GeneratedMethodAccessor229.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy68.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor188.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:792)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:274)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: org.geoserver.platform.ServiceException: org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:939)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:336)
… 105 more
Caused by: org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1390)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:1228)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:1194)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1143)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:863)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:842)
at org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:147)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:221)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:211)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:419)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverages(GridCoverageReaderHelper.java:205)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:773)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:743)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:852)
… 106 more
Caused by: java.io.IOException: java.util.concurrent.ExecutionException: java.lang.IndexOutOfBoundsException: imageIndex out of bounds!
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.collectGranules(RasterLayerResponse.java:512)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.access$2400(RasterLayerResponse.java:340)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.produce(RasterLayerResponse.java:1064)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.access$3100(RasterLayerResponse.java:883)
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1342)
… 119 more
Caused by: java.util.concurrent.ExecutionException: java.lang.IndexOutOfBoundsException: imageIndex out of bounds!
at java.util.concurrent.FutureTask.report(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.collectGranules(RasterLayerResponse.java:447)
… 123 more
Caused by: java.lang.IndexOutOfBoundsException: imageIndex out of bounds!
at com.sun.media.imageioimpl.plugins.tiff.TIFFImageReader.seekToImage(TIFFImageReader.java:307)
at com.sun.media.imageioimpl.plugins.tiff.TIFFImageReader.getWidth(TIFFImageReader.java:512)
at org.geotools.gce.imagemosaic.Utils.getDimension(Utils.java:751)
at org.geotools.gce.imagemosaic.GranuleDescriptor.getLevel(GranuleDescriptor.java:981)
at org.geotools.gce.imagemosaic.GranuleDescriptor.loadRaster(GranuleDescriptor.java:728)
at org.geotools.gce.imagemosaic.GranuleLoader.call(GranuleLoader.java:110)
at org.geotools.gce.imagemosaic.GranuleLoader.call(GranuleLoader.java:41)
at java.util.concurrent.FutureTask.run(Unknown Source)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.accept(RasterLayerResponse.java:406)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.access$2200(RasterLayerResponse.java:340)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.visit(RasterLayerResponse.java:1017)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog$1.visit(CachingDataStoreGranuleCatalog.java:192)
at org.geotools.data.store.ContentFeatureSource.accepts(ContentFeatureSource.java:696)
at org.geotools.data.store.ContentFeatureCollection.accepts(ContentFeatureCollection.java:120)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.getGranuleDescriptors(CachingDataStoreGranuleCatalog.java:158)
at org.geotools.gce.imagemosaic.RasterManager.getGranuleDescriptors(RasterManager.java:1153)
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1339)
… 119 more
-Jukka Rahkonen-
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ing. Nicola Lagomarsini
Junior Software Engineer
On Thu, Sep 25, 2014 at 10:16 AM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
mosaic works again.
Hum yes, as far as I know the image mosaic code was never able to use
external overviews, we have support for those only in the plain
geotiff and world image reader (which mosaic does not use, for performance
reasons it goes down directly to the JAI low level reader)
Simone/Daniele should know more about this.
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea is right.
There is support for GeoTiff and WorldImageReader only, which are GeoTools readers.
ImageMosaic does data access using low level ImageReaders, not the GeoTools ones, therefore that GeoTiff reader capability isn’t used on ImageMosaic machinery.
There is a JIRA to add support for external overviews on other raster formats (so ImageMosaic too).
https://jira.codehaus.org/browse/GEOT-3662
Hope this helps.
Daniele
Ing. Daniele Romagnoli
On Thu, Sep 25, 2014 at 10:29 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Sep 25, 2014 at 10:16 AM, Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com> wrote:
Hum yes, as far as I know the image mosaic code was never able to use external overviews, we have support for those only in the plain
geotiff and world image reader (which mosaic does not use, for performance reasons it goes down directly to the JAI low level reader)
Ing. Andrea Aime
@geowolf
Technical Lead
Unfortunately, I am not able to share the source images that we have been working with. When I have time next week, I will try to find some opensource images that exhibit the same behavior. I can, however, share the commands that we used.
I know the issue showed for some with external overviews, we use internal overviews.
These are the commands I use to generate the files.
first (the original files are SID format that are not 4326; we warp the original SID file to GeoTIFF 4326, generated with external masks
nearblack -of GTiff -near 2 -nb 0 -setmask -setalpha -co TILED=YES --config GDAL_CACHE_MAX 768 -o /mnt/data/2/library/ntc_alphamask/m_3511643_sw_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/1/library/m_3511643_sw_11_1_20100613.sid.4326.tif
nearblack -of GTiff -near 2 -nb 0 -setmask -setalpha -co TILED=YES --config GDAL_CACHE_MAX 768 -o /mnt/data/2/library/ntc_alphamask/m_3511651_ne_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/1/library/m_3511651_ne_11_1_20100613.sid.4326.tif
nearblack -of GTiff -near 2 -nb 0 -setmask -setalpha -co TILED=YES --config GDAL_CACHE_MAX 768 -o /mnt/data/2/library/ntc_alphamask/m_3511651_nw_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/1/library/ m_3511651_nw_11_1_20100613.sid.4326.tif
nearblack -of GTiff -near 2 -nb 0 -setmask -setalpha -co TILED=YES --config GDAL_CACHE_MAX 768 -o /mnt/data/2/library/ntc_alphamask/m_3511643_se_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/1/library/ m_3511643_se_11_1_20100613.sid.4326.tif
Overviews
gdaladdo -r gauss --config GDAL_CACHEMAX 768 --config COMPRESS_OVERVIEW LZW --config OVERVIEW_PREDICTOR 2 /mnt/data/2/library/ntc_alphamask/m_3511643_sw_11_1_20100613.sid.4326.alphamsk.tif 2 4 8 16 32 64 128
gdaladdo -r gauss --config GDAL_CACHEMAX 768 --config COMPRESS_OVERVIEW LZW --config OVERVIEW_PREDICTOR 2 /mnt/data/2/library/ntc_alphamask/m_3511651_ne_11_1_20100613.sid.4326.alphamsk.tif 2 4 8 16 32 64 128
gdaladdo -r gauss --config GDAL_CACHEMAX 768 --config COMPRESS_OVERVIEW LZW --config OVERVIEW_PREDICTOR 2 /mnt/data/2/library/ntc_alphamask/m_3511651_nw_11_1_20100613.sid.4326.alphamsk.tif 2 4 8 16 32 64 128
gdaladdo -r gauss --config GDAL_CACHEMAX 768 --config COMPRESS_OVERVIEW LZW --config OVERVIEW_PREDICTOR 2 /mnt/data/2/library/ntc_alphamask/m_3511643_se_11_1_20100613.sid.4326.alphamsk.tif 2 4 8 16 32 64 128
Compress
gdal_translate -of GTiff --config GDAL_CACHEMAX 768 -co TILED=YES -co COMPRESS=LZW -co PREDICTOR=2 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co COPY_SRC_OVERVIEWS=YES /mnt/data/2/library/nbtests/ntc_alphamask_lzw_ovr/m_3511643_sw_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/2/library/ntc_alphamask_lzw_lzw_ovr/m_3511643_sw_11_1_20100613.sid.4326.alphamsk.lzw.tif
gdal_translate -of GTiff --config GDAL_CACHEMAX 768 -co TILED=YES -co COMPRESS=LZW -co PREDICTOR=2 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co COPY_SRC_OVERVIEWS=YES /mnt/data/2/library/nbtests/ntc_alphamask_lzw_ovr/m_3511651_ne_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/2/library/ntc_alphamask_lzw_lzw_ovr/m_3511651_ne_11_1_20100613.sid.4326.alphamsk.lzw.tif
gdal_translate -of GTiff --config GDAL_CACHEMAX 768 -co TILED=YES -co COMPRESS=LZW -co PREDICTOR=2 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co COPY_SRC_OVERVIEWS=YES /mnt/data/2/library/nbtests/ntc_alphamask_lzw_ovr/m_3511651_nw_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/2/library/ntc_alphamask_lzw_lzw_ovr/m_3511651_nw_11_1_20100613.sid.4326.alphamsk.lzw.tif
gdal_translate -of GTiff --config GDAL_CACHEMAX 768 -co TILED=YES -co COMPRESS=LZW -co PREDICTOR=2 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co COPY_SRC_OVERVIEWS=YES /mnt/data/2/library/nbtests/ntc_alphamask_lzw_ovr/m_3511643_se_11_1_20100613.sid.4326.alphamsk.tif /mnt/data/2/library/ntc_alphamask_lzw_lzw_ovr/m_3511643_se_11_1_20100613.sid.4326.alphamsk.lzw.tif
The final folder, /mnt/data/2/library/ntc_alphamask_lzw_lzw_ovr, is where we point the image mosaic plugin.
The generated properties file contents:
#-Automagically created from GeoTools-
#Fri Sep 12 18:35:31 GMT 2014
Levels=9.872874985361126E-6,9.872874985361126E-6 1.9745749970722252E-5,1.9742893236062137E-5 3.948029349991742E-5,3.9485786472124275E-5 7.896058699983484E-5,7.897157294424855E-5 1.5774212504955667E-4,1.579431458884971E-4 3.147704848273959E-4,3.158862917769942E-4 6.267051995212117E-4,6.317725835539884E-4 0.0012422192347652588,0.0012635451671079768
Heterogeneous=true
AbsolutePath=false
Name=ntc_alphamask_lzw_lzw_ovr
TypeName=ntc_alphamask_lzw_lzw_ovr
Caching=false
ExpandToRGB=false
LocationAttribute=location
SuggestedSPI=com.sun.media.imageioimpl.plugins.tiff.TIFFImageReaderSpi
CheckAuxiliaryMetadata=false
LevelsNum=8
Gdalinfo
gdalinfo m_3511643_se_11_1_20100613.sid.4326.alphamsk.lzw.tif
Driver: GTiff/GeoTIFF
Files: m_3511643_se_11_1_20100613.sid.4326.alphamsk.lzw.tif
m_3511643_se_11_1_20100613.sid.4326.alphamsk.lzw.tif.msk
Size is 7058, 6920
Coordinate System is:
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Origin = (-116.691062837404260,35.315395700933692)
Pixel Size = (0.000009871719474,-0.000009871719474)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left (-116.6910628, 35.3153957) (116d41’27.83"W, 35d18’55.42"N)
Lower Left (-116.6910628, 35.2470834) (116d41’27.83"W, 35d14’49.50"N)
Upper Right (-116.6213882, 35.3153957) (116d37’17.00"W, 35d18’55.42"N)
Lower Right (-116.6213882, 35.2470834) (116d37’17.00"W, 35d14’49.50"N)
Center (-116.6562255, 35.2812396) (116d39’22.41"W, 35d16’52.46"N)
Band 1 Block=512x512 Type=Byte, ColorInterp=Red
Overviews: 3529x3460, 1765x1730, 883x865, 442x433, 221x217, 111x109, 56x55
Mask Flags: PER_DATASET
Band 2 Block=512x512 Type=Byte, ColorInterp=Green
Band 3 Block=512x512 Type=Byte, ColorInterp=Blue
Band 4 Block=512x512 Type=Byte, ColorInterp=Alpha
gdalinfo m_3511643_sw_11_1_20100613.sid.4326.alphamsk.lzw.tif
Files: m_3511643_sw_11_1_20100613.sid.4326.alphamsk.lzw.tif
m_3511643_sw_11_1_20100613.sid.4326.alphamsk.lzw.tif.msk
Size is 7046, 6911
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Origin = (-116.753518404261229,35.315359037309236)
Pixel Size = (0.000009872874985,-0.000009872874985)
Metadata:
AREA_OR_POINT=Area
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left (-116.7535184, 35.3153590) (116d45’12.67"W, 35d18’55.29"N)
Lower Left (-116.7535184, 35.2471276) (116d45’12.67"W, 35d14’49.66"N)
Upper Right (-116.6839541, 35.3153590) (116d41’ 2.23"W, 35d18’55.29"N)
Lower Right (-116.6839541, 35.2471276) (116d41’ 2.23"W, 35d14’49.66"N)
Center (-116.7187363, 35.2812433) (116d43’ 7.45"W, 35d16’52.48"N)
Overviews: 3523x3456, 1762x1728, 881x864, 441x432, 221x216, 111x108, 56x54
gdalinfo m_3511651_ne_11_1_20100613.sid.4326.alphamsk.lzw.tif
Files: m_3511651_ne_11_1_20100613.sid.4326.alphamsk.lzw.tif
m_3511651_ne_11_1_20100613.sid.4326.alphamsk.lzw.tif.msk
Size is 7059, 6921
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Origin = (-116.691057906324772,35.252890026569027)
Pixel Size = (0.000009868690930,-0.000009868690930)
Metadata:
AREA_OR_POINT=Area
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left (-116.6910579, 35.2528900) (116d41’27.81"W, 35d15’10.40"N)
Lower Left (-116.6910579, 35.1845888) (116d41’27.81"W, 35d11’ 4.52"N)
Upper Right (-116.6213948, 35.2528900) (116d37’17.02"W, 35d15’10.40"N)
Lower Right (-116.6213948, 35.1845888) (116d37’17.02"W, 35d11’ 4.52"N)
Center (-116.6562264, 35.2187394) (116d39’22.41"W, 35d13’ 7.46"N)
Overviews: 3530x3461, 1765x1731, 883x866, 442x433, 221x217, 111x109, 56x55
gdalinfo m_3511651_nw_11_1_20100613.sid.4326.alphamsk.lzw.tif
Files: m_3511651_nw_11_1_20100613.sid.4326.alphamsk.lzw.tif
m_3511651_nw_11_1_20100613.sid.4326.alphamsk.lzw.tif.msk
Size is 7048, 6913
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Origin = (-116.753509580714450,35.252853245491274)
Pixel Size = (0.000009869711997,-0.000009869711997)
Metadata:
AREA_OR_POINT=Area
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left (-116.7535096, 35.2528532) (116d45’12.63"W, 35d15’10.27"N)
Lower Left (-116.7535096, 35.1846239) (116d45’12.63"W, 35d11’ 4.65"N)
Upper Right (-116.6839479, 35.2528532) (116d41’ 2.21"W, 35d15’10.27"N)
Lower Right (-116.6839479, 35.1846239) (116d41’ 2.21"W, 35d11’ 4.65"N)
Center (-116.7187287, 35.2187386) (116d43’ 7.42"W, 35d13’ 7.46"N)
Overviews: 3524x3457, 1762x1729, 881x865, 441x433, 221x217, 111x109, 56x55
Folder contents:
ntc_alphamask_lzw_lzw_ovr.dbf
ntc_alphamask_lzw_lzw_ovr.fix
ntc_alphamask_lzw_lzw_ovr.prj
ntc_alphamask_lzw_lzw_ovr.properties
ntc_alphamask_lzw_lzw_ovr.qix
ntc_alphamask_lzw_lzw_ovr.shp
ntc_alphamask_lzw_lzw_ovr.shx
sample_image
Chris Snider
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@…486…]
Sent: Thursday, September 25, 2014 2:16 AM
To: ‘Nicola Lagomarsini’; ‘Geoserver-users@lists.sourceforge.net’
-Jukka Rahkonen-
Hi Chris,
Nicola Lagomarsini.
Chris Snider
To: Andrea Aime
Nicola Lagomarsini.
Hi Jukka,
width: 12000
height: 12000
scaleX: 1.0
scaleY: 1.0
GEOGCS[“ETRS89”,
UNIT[“m”, 1.0],
… 105 more
… 106 more
… 119 more
… 123 more
… 119 more
-Jukka Rahkonen-
Ing. Andrea Aime
@geowolf
Technical Lead
