[Geoserver-users] Mysql datastore charset error
I'm using geoserver 1.5.4
I have utf-8 encoded tables in mysql database as a feature source.They
contains some Chinese characters. However, the result of WMS has charset
error which the Chinese char displayed as "???".
I don't know how to handle this problem. It seems that the same thing
with PostgreSQL is all right. I have checked the configuration and even
the code , nothing found.
Could help me?
Could help me?
The MySql datastore is not actively mantained at the moment, we
don't have any developer really familiar with MySql either.
Yet, I don't think we're doing anything special in PostGis to make it
properly use the UTF-8 charset. Do you know if any special setting is
needed in the MySql JDBC driver or jdbc url connection to make it work
with UTF-8 chars?
Can you verify that the data shows up correctly when you query it from
the command line? I ran into this problem a while ago as well when
trying to load data with extended latin characters into a mysql
database. I agree with andrea... the datastore does not do anything
special that i know of to support extended charsets.
Could help me?
with UTF-8 chars?
!DSPAM:4007,47907a1a272655409313003!
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
