[Geoserver-users] mysql featureType NullPointerException
I'm a beginner in Geoserver so I need some help.
I try to add mysql featureType but I get this message:
java.lang.NullPointerException
  at
org.vfny.geoserver.global.FeatureTypeInfo.getRegionateFeatureLimit(FeatureTypeInfo.java:1671)
  at
org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:514)
  at org.vfny.geoserver.global.Data.toDTO(Data.java:1593)
  at
org.vfny.geoserver.action.SaveXMLAction.saveGeoserver(SaveXMLAction.java:63)
  at org.vfny.geoserver.action.SaveXMLAction.execute(SaveXMLAction.java:45)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at
  at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at
  at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at
  at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
View this message in context: http://www.nabble.com/mysql-featureType-NullPointerException-tp19858211p19858211.html
Which version of GeoServer are you using? Also what are the steps you took to receive the error? The following:
1. Add the mysql database
2. Add the feature type for the table
3. Apply
4. Save
A bit more info should help us solve the problem.
-Justin
danielas1 wrote:
Hi, I'm a beginner in Geoserver so I need some help. I try to add mysql featureType but I get this message:
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
Justin Deoliveira
OpenGeo - http://opengeo.org
HI,
I'm using Geoserver 1.7 and Mysql 5.1 (Windows) and followed the geoserver
administration web configuration interface and the mysql featuretype adding
presented on Geoserver documentation site.
I get the error when I try to "Apply" the feaaturetype. I use 2170 (Slovenia
Grid) SRS projection.
The think is that I used the same data in a Postgis table and the procedure
of adding a new featuretype works fine. I plan to use Mysql but it is not
working for me.
Justin Deoliveira-6 wrote:
3. Apply
4. Save
-Justin
danielas1 wrote:
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
Justin Deoliveira
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
View this message in context: http://www.nabble.com/mysql-featureType-NullPointerException-tp19858211p19935036.html
Thanks for the info. Is there any chance you can send over a dump of some of your data. The error message is not so informing about what is going on. It would be helpful if i could load your data and try to reproduce here.
Feel free to send the data in a private email to me.
-Justin
danielas1 wrote:
HI, I'm using Geoserver 1.7 and Mysql 5.1 (Windows) and followed the geoserver
working for me.
3. Apply
4. Save
-Justin
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
Justin Deoliveira
challenge
prizes
world
Justin Deoliveira
