Hi All
I was running into some trouble with the versioning component of geoserver 1.6.0. I am using a modified version of the preliminary demo at http://sigma.openplans.org/~tschaub/wfsv/feature-editor.html. I run into an error when I try to compare revisions of my data. The error that I get is as follows: “Parsing failed for typeName: java.lang.IllegalArgumentException: prefix localhost is not bound to a namespace”. I think I made all the necessary changes to the Editor.js script, which I believe provides all the functions needed for comparing revisions (see http://sigma.openplans.org/~tschaub/wfsv/script/Editor.js). In fact, I just noticed that the preliminary demo (see URL above) also gives the same error when one tries to compare revisions of data. It’s probably not a geoserver issue, but any suggestions will be most appreciated.
Chetan
Hi Chetan,
Any chance you can get us a copy of the request, perhaps with firebug? If not the GeoServer logs from the console or your servlet container would help as well.
-Justin
Chetan Tiwari wrote:
Hi All
I was running into some trouble with the versioning component of geoserver 1.6.0. I am using a modified version of the preliminary demo at http://sigma.openplans.org/~tschaub/wfsv/feature-editor.html. I run into an error when I try to compare revisions of my data. The error that I get is as follows: "Parsing failed for typeName: java.lang.IllegalArgumentException: prefix localhost is not bound to a namespace". I think I made all the necessary changes to the Editor.js script, which I believe provides all the functions needed for comparing revisions (see http://sigma.openplans.org/~tschaub/wfsv/script/Editor.js). In fact, I just noticed that the preliminary demo (see URL above) also gives the same error when one tries to compare revisions of data. It's probably not a geoserver issue, but any suggestions will be most appreciated.
Chetan
!DSPAM:4007,47b88a87279262092453641!
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hi Chetan,
Thanks for the extra info. It seems that openlayers is creating the request with the localhost namespace prefix. Is that the prefix attached to your feature type? If you include the wfs caps document that should tell us.
Hi Justin
Thanks for your mail. Here is the output from firebug:
Headers
Response Headers
Content-Type text/xml; charset=UTF-8
Transfer-Encoding chunked
Connection keep-alive
Server Jetty(6.0.2)
Request Headers
Host localhost:8080
User-Agent Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.8.1.12 <http://1.8.1.12/>\) Gecko/20080201 Firefox/2.0.0.12
Accept text/javascript, text/html, application/xml, text/xml, */*
Accept-Language en-us,en;q=0.5
Accept-Encoding gzip,deflate
Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive 300
X-Requested-With XMLHttpRequest
OpenLayers true
Content-Type application/xml
Referer http://localhost:8080/geoserver/feature-editor3.html
Content-Length 228
Pragma no-cache
Cache-Control no-cache
Post
<wfsv:GetDiff xmlns:wfsv="http://www.opengis.net/wfsv" service="WFSV" version="1.0.0" outputFormat="HTML"
><wfsv:DifferenceQuery typeName="localhost:school_districts" fromFeatureVersion="17" toFeatureVersion
="18"/></wfsv:GetDiff>
Response
<?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception
.xsd">
<ServiceException>
java.lang.RuntimeException: Parsing failed for typeName: java.lang.IllegalArgumentException: prefix
namespace
</ServiceException></ServiceExceptionReport>
I am also attaching copies of the following files:
1. editor.js
2. feature-editor.html
Thanks very much for your help,
Chetan
Chetan Tiwari
Dept. of Geography, The Univ. of Iowa
316 Jessup Hall, Iowa City, IA 52242
Ph. (319) 335-0165 Fax (319) 335-2725
!DSPAM:4007,47b92362102833327367457!
Editing Options
* View History <#>
* Preferences <#>
Justin Deoliveira
