[Geoserver-users] Native JAI set to False
I am using the integrated installation of GeoServer and GeoWebCache (not the suite). I see in the documentation that Native JAI needs to be installed and set to True. It is installed. But the GeoServer Status page says that Native JAI is False. How do I change the status from False to True?
Thanks!
Ciao David,
if JAI is properly installed you need to check the relative checkbox
in the JAI Settings panel:
http://docs.geoserver.org/stable/en/user/webadmin/server/JAI.html
However if in the status page native JAI is false that means it was
not installed properly.
Can you elaborate a bit on what your OS is and what you did to install
native JAI?
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Sep 23, 2013 at 5:27 PM, David McKinney <geomatney@anonymised.com> wrote:
Thanks!
LIMITED TIME SALE - Full Year of Microsoft Training For Just $49.99!
1,500+ hours of tutorials including VisualStudio 2012, Windows 8, SharePoint
2013, SQL 2012, MVC 4, more. BEST VALUE: New Multi-Library Power Pack
includes
Mobile, Cloud, Java, and UX Design. Lowest price ever! Ends 9/20/13.
http://pubads.g.doubleclick.net/gampad/clk?id=58041151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ciao David,
please, find my answers inline below...
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Mon, Sep 23, 2013 at 7:41 PM, David McKinney <geomatney@anonymised.com> wrote:
Ciao Simone,
Thank you for responding.
I'm on a Linux server. I am not running the GeoServer Suite. Rather, I am
only using the GeoServer and GeoWebCache.
I finally got the JAI installed correctly, I think. It took several attempts
to download a .bin file from the documentation link that was not corrupted.
I was able to install the following: jai-1_1_3-lib-linux-amd64-jre.bin
An alternative way of installing them is to get the tar.gz and place
the SO it contains under something like
/usr/lib/jvm/jdk1.6.0_45/jre/lib/amd64 or /usr/lib/jvm/jdk1.6.0_45/jre/lib/i386
After restarting Apache Tomcat6, I see TRUE for Native JAI.
However, Native JAI ImageIO is still FALSE.
That's because you only installed Native JAI. Native ImageIO is a
separate set of SO to be installed similarly but separately.
I need to do a little more testing and reading to see if Native JAI ImageIO
= TRUE is required for my needs. Perhaps you can offer some insight?
It speeds up PNG serving. For JPEG I do recommend using the Libjpeg
turbo extension instead,
http://docs.geoserver.org/stable/en/user/community/libjpeg-turbo/index.html
I am now attempting to upload hundreds of Geotiffs as a bulk upload. This is
the primary goal of my endeavor.
To date, I have only been able to figure out how to upload one geotiff at a
time.
I need to be able to load the geotiffs to the GeoServer and have the WMS
create the necessary 512x512 tiles at different resolutions.
Do you know do I get hundreds of files uploaded as a coverage, such that
they can be tiled and served?
If these files are part of a mosaic (e.g. orthos) you can put them
inside the directory and then use the imagemosaic to create a mosaic
by pointing to the parent directory. I would give a shot at these
slides (the new version will be online soon):
http://goo.gl/TXJRS
Just to add a bit to my thoughts, if you want to serve a mosaic off
100+ files at all scales this might be problematic since
you might end up opening too many files at once to answer a request at
large scales. Anyway, if you'll get to this point
I'll help you again, I believe first thing is to get some confidence
in using GeoServer.
Thanks for any assistance you can offer.
David
On Mon, Sep 23, 2013 at 12:45 PM, Simone Giannecchini
<simone.giannecchini@anonymised.com> wrote:
Ciao David,
native JAI?
Simone Giannecchini
more information.
@simogeo
Founder/Director
> the
> and
> Native
> Thanks!
> SharePoint
> includes
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
