In order to diagnose a performance problem [1] we would like to capture ALL SQL statements emitted by GeoServer to Oracle. It appears that many of the metadata queries are not logged.
Oracle JDBC drivers support logging internally [2]. Has anyone tried this, and is it possible to enable this by simply creating a new logging properties file in GeoServer? Or is it necessary to follow the more complicated configuration documented by Oracle?
[1] http://osgeo-org.1560.x6.nabble.com/Issue-with-internal-connection-pooling-for-Oracle-datastore-with-no-schema-name-td5217844.html
[2] http://docs.oracle.com/cd/B28359_01/java.111/b31224/diagnose.htm
Thanks for the suggestions, Jonathan.
We did try cranking up the logging level, but I think the problematic queries are not logged. We didn’t see them, anyway
The SQL history tip looks very useful…
Did think about a wire sniffer, but we don’t have that level of access. And it seems like it might be hard to interpret the raw wire data…
In the end we were able to enable DB session tracing and that gave us what we needed to identify the problem. For reference, here’s what we did:
- Put this into the datastore Session Startup SQL:
BEGIN; DBMS_SESSION.SET_IDENTIFIER(‘GEOSERVER’); END;
This puts “GEOSERVER” in the user session variable CLIENT_IDENTIFIER.
- In the database, a DBA needs to do this to start tracing:
EXECUTE DBMS_MONITOR.CLIENT_ID_TRACE_ENABLE(client_id => ‘GEOSERVER’);
- Run the GeoServer query.
- Stop tracing:
EXECUTE DBMS_MONITOR.CLIENT_ID_TRACE_DISABLE(client_id => ‘GEOSERVER’);
On Wed, Sep 2, 2015 at 3:57 AM, Jonathan Moules <jonathan@anonymised.com> wrote:
Hi Martin,
I’ll leave the driver level suggestions to those more knowledgeable, but have you tried:
- Setting the GeoServer /Geotools logging level to GeoTools developer logging? In my experience this seems to log most things, including some of the metadata queries
- Ask Oracle what it has been up to recently: http://stackoverflow.com/questions/14830875/find-out-the-history-of-sql-queries
- Failing that, maybe try using some packet sniffer intermediate to watch the requests as they go by; not sure if fiddler2 can handle this type of packet.
Jonathan
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
