[Geoserver-users] nativeName in featuretype
I made a test by renaming layer "poly_landmsrks" into "poly_test". In featuretype.xml I have now
<name>poly_test</name>
<nativeName>poly_landmarks</nativeName>
and this request brings me data:
http://localhost:8080/geoserver/wfs?service=wfs&version=1.0.0&request=getfeature&typename=poly_test
The purpose of name and nativeName is to allow renaming published layers easily. In the past, if I remember right, layers were always published with the default names and especially in case of large databases together with database admins who had developed some fine naming traditions that was leading sometimes to very unfriendly layer names. Only workaround I knew was to create a view into database only for changing the layer name.
-Jukka Rahkonen-
Feniks wrote:
Hello.
I was trying to figure out the purpose of "nativeName" in a featuretype.xml, but
I hit a wall.
I tried some combinations:
- If "nativeName" is different from the "name" the featuretype does not work
- Without "nativeName" it seems to work fine
- Without "name" it does not work
By my logic "nativeName" doesn't seem to be of any use.
So could someone please explain me whats the purpose of "nativeName"?
Thanks for any help.
View this message in context: http://osgeo-
org.1560.x6.nabble.com/nativeName-in-featuretype-tp5156098.html
Geoserver-users mailing list
Thank you for a fast reply and for the explaination.
View this message in context: http://osgeo-org.1560.x6.nabble.com/nativeName-in-featuretype-tp5156098p5156124.html
