[Geoserver-users] nearest neighbor interpolation
Is there a way to smooth the overlay lines using nearest neighbor interpolation?
Dominique Bessette
On Mon, Aug 10, 2015 at 6:52 PM, Bessette-Halsema, Dominique E <
interpolation?
The overlay lines? Interpolation is used only for raster data... can you
show us visually what you mean?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
