[Geoserver-users] Need GML datastore help
I'm having trouble to get the GML datastore (v2.3.5, v2.4.5 &
v.2.5-SNAPSHOT) working.
First i need to use the full path of the GML directory, not the file itself.
So making a new Datastore is no problem, but when i want to make a new
FeatureType I get errors like these:
15:54:58,156 INFO [STDOUT] 23 okt 15:54:58 WARN [action.RequestProcessor] -
Unhandled Exception thrown: class java.lang.IllegalArgumentException
15:54:58,156 ERROR [[action]] Servlet.service() for servlet action threw
exception
java.lang.IllegalArgumentException: FeatureType is required for
FeatureTypeConfig
        at
org.vfny.geoserver.config.FeatureTypeConfig.<init>(FeatureTypeConfig.java:165)
        at
org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:72)
        at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:102)
        at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
        at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
        at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
        at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at
        at
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
        at
        at
        at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
        at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
        at
org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:179)
        at
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
        at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at
org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:157)
        at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:262)
        at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
        at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
        at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:446)
        at java.lang.Thread.run(Thread.java:619)
I know the GML datastore isn't supported and experimental. Is someone using
a GML datastore (wrote it himself or something)?
View this message in context: http://www.nabble.com/Need-GML-datastore-help-tp20131964p20131964.html
Unfortunately the GML datastore is quite unstable... and unmaintained :(. However, if you could provide a sample of some of the gml data you are trying to serve up I can try it on my machine and see if I can find the problem. Unfortunately the error message is not all that informing.
-Justin
MystyxMac wrote:
exception
FeatureTypeConfig
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Justin Deoliveira
OpenGeo - http://opengeo.org
