On Wed, Oct 14, 2015 at 11:32 AM, Chrishelring <christianhelring@anonymised.com>
wrote:
We got a Geoserver installed publishing out spatial data as WMS/WFS. We now
have a request from one of our users who needs KML. I first tried with the
standard "KML" (under "layer preview" --> "Common Formats"). Unfortunately
they cannot use that. It seems that the standard KML service is just a
wrapped URL string in a KML-style format, but what they need is the reel
KML
data published as a service. Is there any way to do that?
There are two KML output format in recent GeoServer versions, a styled one
from WMS, which
is the main link you see, and a WFS KML output format, with attributes but
no styling.
Not sure what "real KML" is though, both output formats generate valid,
compliant KML :-p
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
