Hi geoserver community,
i'm using geoserver in an SOA and an orchestration engine needs to
read and validate the GetCapabilities and DescribeLayer documents
automatically against an xml schema i defined (i know normally it is
validated against a dtd but here it is different).
Is there a possibility to suppress the insertation of the
doctype-element into these documents? The best would be to be able to
switch it somewhere on the configuration gui. If not, where do i find
this in the code?
Thanks
Albrecht
________________________________________________________________
Albrecht Weiser, Dipl.-Ing (FH)
Institut für Raumbezogene Informations- und Messtechnik, i3mainz
Fachhochschule Mainz
Holzstraße 36
55116 Mainz
Tel.: 06131/2859-689
Fax: 06131/2859-699
mailto:weiser@anonymised.com
