On Sat, Jan 30, 2016 at 8:54 AM, RohitGarg DevLead <rohit.garg@anonymised.com>
wrote:
I was approx. published 300 layers, 200 stores and 100 workspaces. But my
services working slow. Can someone please help me out to increase the
performance of geoserver windows setup and data is coming from postgres.
This presentation contains a number of hints regarding performance
optimization:
http://www.slideshare.net/geosolutions/geoserver-on-steroids-foss4g-2015
The summary is, first optimize your data for web serving, then optimize the
styling,
then optimize the software. Do it in a different order, and you'll probably
get limited benefit.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
