Hi List,
Being new to using the REST API I would like to ask you how to create a nested layergroup through the REST API?
My curl is:
curl -v -u user:pwd -XPOST -H ‘Content-type: text/xml’ -d “20132013CONTAINER201304” http://localhost:8080/geoserver/rest/workspaces/myworkspace/layergroups
Where “2013” is the new layerGroup and “201304” is an existing layerGroup.
I could successfully create a layerGroup consisting of plain layers.
Thanks for your views on this,
Csaba
Sándor Csaba
szolgáltatási vezető
ViaMap Kft.
Székhely/postacím: 2176 Erdőkürt, Téglaház utca 4.
Iroda:
1076 Budapest, Garay u. 29-31. I. 1.
(EMLA Környezeti Management és Jog Egyesület)
Tel: +3630/9605853
Fax: +3617002542
On Mon, Apr 22, 2013 at 4:44 PM, Sandor Csaba <sandor.csaba@anonymised.com>wrote:
Hi List,
My curl is:
curl -v -u user:pwd -XPOST -H 'Content-type: text/xml' -d
"<layerGroup><name>2013</name><title>2013</title><mode>CONTAINER</mode><layers><layer>201304</layer></layers></layerGroup>"
Where "2013" is the new layerGroup and "201304" is an existing layerGroup.
The general advice when you are looking at some REST construct that lacks
documentation is
simple, and always the same:
- configure what you need in the GUI
- use GET requests to gather the resources you modified and look at their
structure
- repeat it with your REST api calls
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the hint!
The curl that actually did the job:
curl -v -u user:pwd -XPOST -H ‘Content-type: text/xml’ -d “2008CONTAINER2008icecapicecap:200801-40000004000000-40000004000000EPSG:3411” http://localhost:8080/geoserver/rest/layergroups
Strange enough (for me) that this is completely different from the “normal” not-nested-layergroup creation.
Thanks again,
Csaba
On 23 April 2013 09:07, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Apr 22, 2013 at 4:44 PM, Sandor Csaba <sandor.csaba@anonymised.com> wrote:
Try New Relic Now & We’ll Send You this Cool Shirt
New Relic is the only SaaS-based application performance monitoring service
that delivers powerful full stack analytics. Optimize and monitor your
browser, app, & servers with just a few lines of code. Try New Relic
and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_apr
Geoserver-users mailing list
Sándor Csaba
ViaMap Kft.
Iroda:
Tel: +3630/9605853
Fax: +3617002542
Hi List,
My curl is:
The general advice when you are looking at some REST construct that lacks documentation is
- use GET requests to gather the resources you modified and look at their structure
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Apr 23, 2013 at 3:06 PM, Sandor Csaba <sandor.csaba@anonymised.com>wrote:
"<layerGroup><name>2008</name><mode>CONTAINER</mode><title>2008</title><workspace><name>icecap</name></workspace><publishables><published
type='layerGroup'><name>icecap:200801</name></published></publishables><bounds><minx>-4000000</minx><maxx>4000000</maxx><miny>-4000000</miny><maxy>4000000</maxy><crs
class='projected'>EPSG:3411</crs></bounds></layerGroup>"
"normal" not-nested-layergroup creation.
Yes, the data structures had to be changed completely in order
to accommodate the mix of normal layers and layer groups
Ing. Andrea Aime
@geowolf
Technical Lead
OK so far so good. Next one: how can I add a new layer to a group?
Do I have to resubmit the whole layergroup definition to the existing layergroup endpoint (http://localhost:8080/geoserver/rest/layergroups/myLayerGroup) with -XPUT?
(Actually tried this and resulted in an empty layergroup looking at it on the GUI)
Any hint on this?
Csaba
On 23 April 2013 15:07, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Apr 23, 2013 at 3:06 PM, Sandor Csaba <sandor.csaba@anonymised.com> wrote:
Sándor Csaba
ViaMap Kft.
Iroda:
Tel: +3630/9605853
Fax: +3617002542
Yes, the data structures had to be changed completely in order to accommodate the mix of normal layers and layer groups
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Apr 24, 2013 at 9:55 PM, Sandor Csaba <sandor.csaba@anonymised.com>wrote:
with -XPUT?
Yes, that's the way
the GUI)
Hmm... not sure why. If you can reproduce it with the sample data
directory, please open a bug report at jira.codehaus.org
(register at xircles.codehaus.org if you don't have an account), and
provide the exact call you're making
Ing. Andrea Aime
@geowolf
Technical Lead
