[Geoserver-users] netCDF and WCS
Hi All,
I’d like to create a coverage store that reads a group of netCDF files as input data. Is this possible? I see various references to this in list messages, but cannot find any official docs that describe how to implement such a thing.
Thanks for any insights you could share on this topic.
Roger
Ciao Roger,
there is an unsupported netCDF plugin inside geotools which was known
(I believe to work with GeoServer.
There some work that we are doing on in a branch for netCDF-CF but I
do not think that would be helpful for you in the short term.
Just out of curiosity, saying I have a nunch of netcdf files is a bit
of a generic statement being netcdf so generic, what type of netcdf do
you have? Do they follow any standard?
Ciao,
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Mon, Feb 23, 2009 at 9:05 PM, Roger André <randre@anonymised.com> wrote:
Hi All,
I'd like to create a coverage store that reads a group of netCDF files as
such a thing.
Roger
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Salut Simone,
Thanks for the info. At the moment I am trying to use a sample file from the Unidata site, http://www.unidata.ucar.edu/software/netcdf/examples/tos_O1_2001-2002.nc. It is a CF convention file of gridded data about sea temperatures. I would like to setup a WCS service that can query this file for a specific layer in it named “tos”. I haven’t worked much with either netCDF or WCS, so this is proving to be interesting. :wink:
Regarding the geotools netCDF plugin that you mention below, can you tell me how I could try using it to accomplish what I’m trying to do? I will be working from a fresh install of GeoServer, so I can install whatever is needed, I’m just not exactly sure what that is, or how to implement it.
Thanks again,
Roger
On Mon, Feb 23, 2009 at 3:19 PM, Simone Giannecchini <simone.giannecchini@anonymised.com.> wrote:
Ciao Roger,
Ciao,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi All,
such a thing.
Roger
Hello Roger:
Do you have your own netcdf files that you want to server through
Geoserver? Like Simone mentioned, there are a number of known netcdf
format conventions that are currently recognized by the java netcdf
library.
If you can point us to a sample netcdf file, one that you want to use
in your end result, we can try to display it in Geoserver and then to
get you going with using the netcdf plugin too.
Alex
On 2/24/09, Roger André <randre@anonymised.com> wrote:
Salut Simone,
the Unidata site,
it named "tos". I haven't worked much with either netCDF or WCS, so this is
proving to be *interesting*. :wink:
how I could try using it to accomplish what I'm trying to do? I will be
needed, I'm just not exactly sure what that is, or how to implement it.
Thanks again,
Roger
<simone.giannecchini@anonymised.com> wrote:
> Ciao Roger,
> Ciao,
> Simone.
> GeoSolutions S.A.S.
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> fax: +39 0584983027
> > Hi All,
as
implement
> > such a thing.
> > Roger
Francisco, CA
Enterprise
participation
SFAD
> > _______________________________________________
> > Geoserver-users@lists.sourceforge.net
CA
Enterprise
participation
SFAD
