[Geoserver-users] NetCDF Compression Settings
Hello,
I’m trying to enable NetCDF compression via the NetCDF Output plugin in GeoServer 2.8.1. I have set a compression value (5) in both the individual layer settings as well as the global settings; however, all WCS 2.0.1 NetCDF4-Classic responses appear to be the uncompressed file size.
I believe I have verified that they are uncompressed by running the following command:
ncdump –h –s <netcdf file> | grep DeflateLevel
Sample files which are known to be compressed respond with their compression level, but the GeoServer responses do not display anything.
Is there a step I could be missing to enable compression? Has anyone else gotten this working?
Kevin M. Weiss
Software Engineer
Critical Networks / HARRIS CORPORATION
harris.com / kevin.weiss@anonymised.com
