Daniele,
You hit the nail on the head and I feel a bit foolish. I had even reproduced the issue standing up another server, but I guess both times I forgot to configured the additional dimensions for all but the first layer.
Thanks for the help!
-Kevin
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Wednesday, October 14, 2015 2:36 AM
To: Weiss, Kevin <kweiss01@anonymised.com>
Subject: Re: [Geoserver-users] NetCDF Model WCS Question
Dear Kevin,
do you have a more detailed log for that?
Did you also configure all the available dimensions for the other layers, from the Dimension Tab of the layer config?
Please, let us know.
Best Regards,
Daniele
On Tue, Oct 13, 2015 at 6:35 PM, kweiss01@anonymised.com <kweiss01@anonymised.com> wrote:
Hello all,
I’ve been testing the 2.8-RC build to see if the updated NetCDF support (both netcdf and netcdf-output plugins) could provide the functionality we need. Our use case involves hosting 1-n NetCDF model forecast files and providing both WMS and WCS access in different projections. In my test setup I created an ImageMosaic store with sub-directories for each parameter. After publishing the necessary layers I am able to visualize each different parameter via the Layer Preview, however it seems that WCS only works for the first layer published from the Store. WCS 2.0.1 requests for other layers from the Store result in the exception text of “Failed to read the coverage xxx”.
The server throws a stacktrace with the following errors:
ERROR [geoserver.ows] -
org.geoserver.wcs2_0.exception.WCS20Exception: Failed to read the coverage xxx
Caused by: java.lang.NullPointerException
at org.geoserver.wcs2_0.response.WCSDimensionsSubsetHelper.setupDimensionBean(WCSDimensionsSubsetHelper.java:1339)
Has anyone else seen this issue?
-Kevin
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
