Supporting your sample as is, would require some code changes.
In that case, you can consider opening a JIRA containing the sample data and details on the issue to report the problem.
You can contribute yourself the improvements through a github pull request or just wait for a developer taking care of this issue.
Hope this helps.
Daniele
On Tue, Feb 2, 2016 at 4:11 PM, axxis l <axxis1980@anonymised.com> wrote:
Hi Daniele,
the GeoServer Version is 2.8.1
After a few tests, my conjection is also the time unit, even if you have a look to the logfile.
Are there any hints how I can skirting it?
2016-02-02 16:04:15,277 WARN [netcdf.NetCDFFormat] - Unable to connect
org.geotools.data.DataSourceException: Unable to connect
at org.geotools.coverage.io.netcdf.NetCDFReader.(NetCDFReader.java:158)
at org.geotools.coverage.io.netcdf.NetCDFFormat.getReader(NetCDFFormat.java:95)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1441)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1369)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at $Proxy9.getGridCoverageReader(Unknown Source)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:90)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:59)
at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:242)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:566)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:559)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:171)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:96)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:106)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:106)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSuccessfulSave(CoverageStoreNewPage.java:79)
at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:70)
at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:116)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: org.geotools.data.DataSourceException: java.lang.IllegalArgumentException: Couldn’t determine time units from unit string ‘years’
at org.geotools.coverage.io.netcdf.NetCDFAccess.(NetCDFAccess.java:126)
at org.geotools.coverage.io.netcdf.NetCDFDriver.connect(NetCDFDriver.java:92)
at org.geotools.coverage.io.impl.DefaultFileDriver.process(DefaultFileDriver.java:216)
at org.geotools.coverage.io.netcdf.NetCDFReader.(NetCDFReader.java:156)
… 119 more
Caused by: java.lang.RuntimeException: java.lang.IllegalArgumentException: Couldn’t determine time units from unit string ‘years’
at org.geotools.imageio.netcdf.NetCDFImageReader.setInput(NetCDFImageReader.java:266)
at javax.imageio.ImageReader.setInput(ImageReader.java:380)
at org.geotools.coverage.io.netcdf.NetCDFAccess.(NetCDFAccess.java:115)
… 122 more
Caused by: java.lang.IllegalArgumentException: Couldn’t determine time units from unit string ‘years’
at org.geotools.imageio.netcdf.cv.TimeCoordinateVariable$TimeBuilder.(TimeCoordinateVariable.java:79)
at org.geotools.imageio.netcdf.cv.TimeCoordinateVariable.(TimeCoordinateVariable.java:137)
at org.geotools.imageio.netcdf.cv.CoordinateVariable.create(CoordinateVariable.java:120)
at org.geotools.imageio.netcdf.NetCDFGeoreferenceManager.extractCoordinatesVariable(NetCDFGeoreferenceManager.java:172)
at org.geotools.imageio.netcdf.NetCDFGeoreferenceManager.(NetCDFGeoreferenceManager.java:153)
at org.geotools.imageio.netcdf.NetCDFImageReader.init(NetCDFImageReader.java:449)
at org.geotools.imageio.netcdf.NetCDFImageReader.setInput(NetCDFImageReader.java:264)
… 124 more
Von: dany.geotools@anonymised.com <dany.geotools@anonymised.com> im Auftrag von Daniele Romagnoli <daniele.romagnoli@anonymised.com>
Gesendet: Dienstag, 2. Februar 2016 14:46
An: axxis l
Betreff: Re: [Geoserver-users] NetCDF Plugin
Hi Lotta,
do you have any chance to share the full log?
Which version of GeoServer are you using? (2.8.x, X = ?)
I have a doubt in relation to the time unit.
I think that the current code only deals with “seconds/minutes/hours/days since the reference time”.
I’m not sure it will support the “years since date” type.
Let’s see if the log says something more to provide you more feedbacks.
Hope this helps.
Daniele
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
On Tue, Feb 2, 2016 at 1:44 PM, axxis l <axxis1980@anonymised.com…> wrote:
Hi List,
I´m using geoserver 2.8 with netcdf plugin. I am creating a store with netcdf file and I get the following error:
“Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file://Z:.…[26012016.nc](http://26012016.nc) and hints null.”
Is there a problem with the file?
Attached you find a file extract from the .cdl file.
netcdf 26012016 {
dimensions:
lon = 42 ;
lat = 35 ;
time = 7 ;
variables:
float lon(lon) ;
lon:standard_name = “longitude” ;
lon:long_name = “longitude” ;
lon:units = “degrees_east” ;
lon:axis = “X” ;
lon:_CoordinateAxisType = “Lon” ;
float lat(lat) ;
lat:standard_name = “latitude” ;
lat:long_name = “latitude” ;
lat:units = “degrees_north” ;
lat:axis = “Y” ;
lat:_CoordinateAxisType = “Lat” ;
float time(time) ;
time:standard_name = “time” ;
time:long_name = “Time” ;
time:units = “years since 2000-07-01” ;
time:calendar = “gregorian” ;
time:_CoordinateAxisType = “Time” ;
float SPEI02(time, lat, lon) ;
SPEI02:units = “z values” ;
SPEI02:long_name = “drought index” ;
SPEI02:missing_value = -999. ;
data:
lon = -9.5, -8.5, … ;
lat = 36.5, 37.5, … ;
time = 0, 1, … ;
SPEI02 =
// SPEI02(0,1, 0-41)
NaNf, NaNf, -0.035, -0.09, -0.155, NaNf, NaNf, NaNf, NaNf, 0.064, 0.204,
0.319, 0.405, 0.449, 0.491, 1.292, 1.485, NaNf, NaNf, NaNf, 0.622, 0.134,
0.085, 0.415, NaNf, NaNf, 0.729, 0.885, 1.006, 0.966, 0.873, 0.678,
0.133, 0.181, 0.19, 0.215, 0.21, NaNf, NaNf, NaNf, NaNf, NaNf,
// SPEI02(0,2, 0-41)
NaNf, NaNf, NaNf, NaNf, NaNf, NaNf, NaNf, NaNf, NaNf, 0.198, 0.295,
0.303, 0.314, 0.354, 0.526, 1.363, 1.549, 1.553, 1.379, 1.101, 0.575,
0.067, 0.004, NaNf, NaNf, 0.528, 0.704, 0.877, 1.07, 1.11, 0.793, 0.48,
0.444, 0.429, 0.511, 0.177, 0.6, NaNf, NaNf, NaNf, NaNf, NaNf,
Thanks and Regards,
Lotta
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
