I am new with geoserver and geotools and I try to set up a new Datastore. This datastore has to interpret queries which may contain bbox, time and viewparams.
I manage to retrieve the filter of the query and either see time or bbox, but not both for a regular getMap request. I see all parameters in the geoserver log in the KVP parameters, but I can not find them back in the query.
My datastore extends ContentDataStore.
Any suggestions on whether I have to set hints or capabilities?
Or which parts of the query may contain the missing information?
Is there a possibility to directly access the KVP parameters via the query when creating the Reader via
protected FeatureReader<SimpleFeatureType, SimpleFeature> getReaderInternal(Query query)
Any suggestions are welcome.
best regards
Andreas
On Thu, Jun 27, 2013 at 2:12 PM, Andreas Wombacher
<a.wombacher@anonymised.com>wrote:
the query.
The bbox is going to be part of the Query, the viewparams are in the query
hints,
the time will be sent down as part of the Filter is you activated the time
dimension in the layer config
You should not need to setup any particular capability, but of course your
feature source should declare that it can do filtering (canFilter() should
return true)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
thanks that helped a lot!
best regards
Andreas
<a.wombacher@anonymised.com <mailto:a.wombacher@anonymised.com>> wrote:
the query.
query hints,
should return true)
Ing. Andrea Aime
@geowolf
Technical Lead
