[Geoserver-users] New here - have some questions
Hi folks,
I have downloaded Geoserver 1.5.4 for experimentation purposes
Please bare with me as this is very new to me.
1) What other additional item do I need to download regarding Geoserver.
Ie., maven, eclipse ( I'm no programmer and this is what brought GeoServer
to my attention - the hopeful lack of programming required )
2) Building actual maps for the web. Is Mapbuilder or Openlayers required
here? or can I simply build going through the data config menu's provided
and actually build and publish my maps out?
View this message in context: http://www.nabble.com/New-here---have-some-questions-tf4737949.html#a13549229
awhitley67 wrote:
Hi folks,
Well other than GeoServer itself you just need java jdk to run it. And
that is it if you just want to be a "user". If you want to be a
developer you will need maven. And likely an IDE. Most developers on the
project use eclipse.
GeoServer ships with openlayers and uses it as a nice way to demo layers
that have been configured. it is not required, you can serve up maps
through straight WMS, but if you are building web applications that
require a mapping component, then it is definitley the way to go.
Let us know if you have any more questions.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin,
Thank you for the quick reply. I'll start diving in now.
Justin Deoliveira-4 wrote:
awhitley67 wrote:
Hi folks,
-Justin
Justin Deoliveira
Geoserver-users mailing list
View this message in context: http://www.nabble.com/New-here---have-some-questions-tf4737949.html#a13551992
