On Fri, Sep 25, 2015 at 1:39 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
Here is a procedure for creating the issue:
Download 4 ortophotos:
http://kartat.kapsi.fi/files/orto/etrs-tm35fin/mavi_v_25000_50/2015/L44/02m/1/L4422A.jp2
http://kartat.kapsi.fi/files/orto/etrs-tm35fin/mavi_v_25000_50/2015/L44/02m/1/L4422B.jp2
http://kartat.kapsi.fi/files/orto/etrs-tm35fin/mavi_v_25000_50/2015/L44/02m/1/L4422C.jp2
http://kartat.kapsi.fi/files/orto/etrs-tm35fin/mavi_v_25000_50/2015/L44/02m/1/L4422D.jp2
Convert JPEG2000 files into GeoTIFFs
gdal_translate -of GTiff -co tiled=yes L4422A.jp2 L4422A.tif
gdal_translate -of GTiff -co tiled=yes L4422B.jp2 L4422B.tif
gdal_translate -of GTiff -co tiled=yes L4422C.jp2 L4422C.tif
gdal_translate -of GTiff -co tiled=yes L4422D.jp2 L4422D.tif
Wow, they really put my machine to the test, gdal was using 6GB+ of memory
during
the translation (no kakadu).
Create store and publish the layer and send GetCoverage:
http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=describecoverage&coverageid=topp__orto_nls
DescribeCoverage from this layer is attached. There are some odd things in
the document:
1) The Envelope in boundedBy has coordinates in wrong order N-E though
they should be E-N
<gml:boundedBy>
<gml:Envelope srsName="http://www.opengis.net/def/crs/EPSG/0/3067"
axisLabels="E N" uomLabels="m m" srsDimension="2">
<gml:lowerCorner>6750000.0 404000.0</gml:lowerCorner>
<gml:upperCorner>6762000.0 416000.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
Fixed as part of https://osgeo-org.atlassian.net/browse/GEOS-7142, I now
get:
gml:Envelope srsName="http://www.opengis.net/def/crs/EPSG/0/3067" axisLabels
<gml:lowerCorner>404000.0 6750000.0</gml:lowerCorner>
<gml:upperCorner>416000.0 6762000.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
Full describe results attached.
2) If may be correct to use the axisOrder rule +2 +1 but other WCS servers
which I have tried do not use it (MapServer, Rasdaman)
<gml:GridFunction>
<gml:sequenceRule axisOrder="+2 +1">Linear</gml:sequenceRule>
<gml:startPoint>0 0</gml:startPoint>
</gml:GridFunction>
This is used to indicate the grid pixels have one orientation, but the axis
order is the opposite.
What do MapServer/Rasdaman do to describe a coverage in
http://www.opengis.net/def/crs/EPSG/0/4326, which has flipped axis in WCS
2.0?
3) It is too difficult for me to follow it the mentioned GridFunction
together with these origin and offsetVectors lead to a correct result or not
<gml:origin>
<gml:Point gml:id="p00_topp__orto_nls" srsName="
http://www.opengis.net/def/crs/EPSG/0/3067">
<gml:pos>6761999.75 404000.25</gml:pos>
</gml:Point>
</gml:origin>
<gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/3067">0\.0
0.5</gml:offsetVector>
<gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/3067">\-0\.5
0.0</gml:offsetVector>
So, first vector is increasing 404000.25 (which is Easting) in 0.5 m
steps, the other is decreasing 6761999.75 (which is Northing in 0.5 m steps
and at some moment the whole coverage is turned around with the
GridFunction.
I attach also WCS 2.0.1 GetCoverage from Mapserver 7.0 so it is possible
to compare how it is expressing boundedBy, origin, and offSet vectors. At
least for me this GML without GridFunction is easier to understand.
Rasdaman is creating GML pretty much alike MapServer.
There seems to be once again half a pixel shifts in the origins from
Geoserver vs. Mapserver.
GeoServer is as far as I know trying to repect the OGC rule of "pixel is
center", which is not how raster data is saved
unfortunately (normally raster data is encoded as pixel is corner instead).
I've then tried running:
http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.0&request=GetCoverage&coverageid=finmosaic
and now GeoServer is busy writing the result to a temp file (we cannot
stream it directly), at least by the looks
of the following trace (which I got using jstack, it's not a recorded
error, it's a way to check what a Java app
is busy working on):
"btpool0-2" prio=10 tid=0x00007f0930006800 nid=0x1c6a runnable
[0x00007f09743ab000]
java.lang.Thread.State: RUNNABLE
at java.io.RandomAccessFile.writeBytes0(Native Method)
at java.io.RandomAccessFile.writeBytes(RandomAccessFile.java:520)
at java.io.RandomAccessFile.write(RandomAccessFile.java:550)
at
javax.imageio.stream.FileCacheImageOutputStream.write(FileCacheImageOutputStream.java:141)
at
it.geosolutions.imageioimpl.plugins.tiff.TIFFNullCompressor.encode(TIFFNullCompressor.java:104)
at
it.geosolutions.imageioimpl.plugins.tiff.TIFFImageWriter.writeTile(TIFFImageWriter.java:1905)
at
it.geosolutions.imageioimpl.plugins.tiff.TIFFImageWriter.write(TIFFImageWriter.java:2920)
at
it.geosolutions.imageioimpl.plugins.tiff.TIFFImageWriter.write(TIFFImageWriter.java:2614)
at
org.geotools.gce.geotiff.GeoTiffWriter.writeImage(GeoTiffWriter.java:427)
at
org.geotools.gce.geotiff.GeoTiffWriter.write(GeoTiffWriter.java:271)
This is going to take a while, the mosaic is 24k by 24k... looking at it,
we probably need some tweaks in the
code to generate such a large output, I can see there are extra operations
in the chain that could be
avoided for this case, and we could force a "reasonable" tiling structure
in the output too, now it's
following the input one, which is... really bad.
Here is a prelim gdalinfo against the temp file, to give you an idea:
gdalinfo /tmp/imageio3762159434441867746.tmp
Driver: GTiff/GeoTIFF
Files: /tmp/imageio3762159434441867746.tmp
Size is 24000, 24000
Coordinate System is:
PROJCS["ETRS89 / TM35FIN(E,N)",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4258"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",27],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3067"]]
Origin = (404000.000000000000000,6762000.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 404000.000, 6762000.000) ( 25d13'33.38"E, 60d58'52.54"N)
Lower Left ( 404000.000, 6750000.000) ( 25d13'54.90"E, 60d52'24.88"N)
Upper Right ( 416000.000, 6762000.000) ( 25d26'51.34"E, 60d59' 2.39"N)
Lower Right ( 416000.000, 6750000.000) ( 25d27'10.18"E, 60d52'34.68"N)
Center ( 410000.000, 6756000.000) ( 25d20'22.45"E, 60d55'43.79"N)
Band 1 Block=24000x8 Type=Byte, ColorInterp=Red
NoData Value=0
Band 2 Block=24000x8 Type=Byte, ColorInterp=Green
NoData Value=0
Band 3 Block=24000x8 Type=Byte, ColorInterp=Blue
NoData Value=0
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
describe.xml (4.13 KB)
