I finally figured out a way to do what i wanted to and its working.
These are the steps i took.
1- Made a map i want to show to my customers.
2- Open it in "preview" save the opened file's code as say example.htm
(mainly openlayers script)
3- Edit the example.htm, Insert my php script, that does the trick.
4- Save the file as myexample.php in my webserver directory.
5- Access as http://mywebserver/example.php… :jumping:
ISSUES :
This way one issue that im having is, the "click on map to get info" feature
is not working.
Havent given it much thot yet.
i am uploading the example.php file so that you guys can improve it further.
http://www.nabble.com/file/p12689486/example.php example.php
Thanks to all the folks who replied to my post.
View this message in context: http://www.nabble.com/New-to-Geoserver-plz-help--Solved--How-to-place-markers-tf4447451.html#a12689486
coderage ha scritto:
ISSUES :
is not working.
This is usually the javascript not being able to call back the site
because the php page is not served by the same host/port as geoserver.
To make this work you'll have to proxy geoserver inside apache/iis.
If using apache, mod_proxy is a solution.
See also:
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#WhydoIneedaProxyHost
http://en.wikipedia.org/wiki/Same_origin_policy
Thanks Andrea, i will chek this out. Meanwhile more serious issue is the
disappearing markers when zoomin in. Kindly tell some solution for that.
kind regards
Code
ISSUES :
feature
is not working.
See also:
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
View this message in context: http://www.nabble.com/New-to-Geoserver-plz-help--Solved--How-to-place-markers-tf4447451.html#a12697388
