Andrea,
Try changing the service to login as a user with admin rights to see if you get access then. I just did that with my 32 bit system and mine started working.
________________________________________
Sent: Wednesday, June 17, 2009 10:15 AM
To: iomeneandrei
Subject: Re: [Geoserver-users] New Windows installer and 64-bit systems
Hi Andrea. You may be on to something. What flavor of Windows are you using? (XP/Vista/7?) The installer was never tested against 64-bit systems, but I believe it should be possible, although we may need to switch out the wrapper.dll.
Could you file a JIRA issue for this? I'll see what I can do...
http://jira.codehaus.org/browse/GEOS
Mike Pumphrey
OpenGeo - http://opengeo.org
iomeneandrei wrote:
I have downloaded and installed the new windows installer. I’m able to start
the service, but I have this error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/geoserver
I have opened the log file, and I have this error:
“Unable to load the Wrapper’s native library ‘wrapper.dll’”
I have a 64-bit windows system. Probably it's impossible to use this
installer with it. Am I right?
Thank you,
Andrea Borruso
email: aborruso@anonymised.com
website: http://blog.spaziogis.it
my 2.0 life: http://aborruso.storytlr.com/
feed: http://feeds2.feedburner.com/Tanto
38° 7' 48" N, 13° 21' 9" E
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
