[Geoserver-users] newbie - Data store / Layer question
I am running GeoServer version 2.4.4 on Windows 7
How do I configure GeoServer to read in a load of tiff files in a folder
Stefan,
If tiffs are (geotiff) correctly geo-referenced and homogeneous (look at
the [1]) and can be logically represented in a single layer (map) you could
try to create a mosaic over that folder.
For limitation and info take a look here:
[1]
http://docs.geoserver.org/stable/en/user/tutorials/image_mosaic_plugin/imagemosaic.html
If those tiffs are geotiff but cannot be represented into the same layer
(map) you have to publish them as separate geotiff files.
Note that tiffs are NOT geotiffs, if you are missing geospatial metadata in
images you probably have to apply some pre-processing before trying to
publish them into geoserver.
Carlo
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
Ciao Stefan,
from GeoServer user manual:
To publish a store from a single tiff file http://docs.geoserver.org/stable/en/user/data/raster/geotiff.html them publish a layer from that store
To publish a layer made by a single mosaic of a tiff file set http://docs.geoserver.org/stable/en/user/data/raster/imagemosaic.html
To bulk Publishing a set of tiff files evaluate to use the GeoServer Rest interface to write your own shell script http://docs.geoserver.org/stable/en/user/rest/api/coveragestores.html. You can also evaluate to use one of the many opensource batch engines available around plus the GS rest interface.
Hope this will help you!
Damiano
ยทยทยท
2014-02-25 22:01 GMT+01:00 Stefan <smaric@anonymised.com>:
