[Geoserver-users] News on GeoServer supporting GDAL (Simplified steps).
Hi lists,
we have slightly simplified the procedure for testing the unofficial GeoServer release supporting GDAL through ImageIO-Ext. (A GeoServer version supporting MrSID, JP2K (MrSID), JP2K (Kakadu), DTED, Erdas Imagine, NITF Format).
The new release is available at http://www.geo-solutions.it/libraries/geoserver-1.7.0-SNAPSHOT-war.zip.
We have set a simple guide with instructions and links to test the release. This guide is available as:
HTML: http://www.geo-solutions.it/doc/geoservergdal.html
PDF: http://www.geo-solutions.it/doc/geoservergdal.pdf
OpenOffice Doc: http://www.geo-solutions.it/doc/geoservergdal.odt
Before testing GeoServer, be sure you have read the section “Some notes on the GeoServer usage” on the ImageIO-EXT-GDAL WIKI page:
http://docs.codehaus.org/display/GEOTOOLS/ImageIO-EXT+GDAL#ImageIO-EXTGDAL-SomenotesontheGeoServerusage%26nbsp%3B
Finally, note that due to licensing issues, the available dynamic libraries enable support for MrSID, JP2K (MrSID), DTED, Erdas Imagine, NITF formats.
If you need to add support to JP2K (Kakadu) and ECW, see instructions available at http://www.geo-solutions.it/doc/ImageioExt-SetupGuide.odt (OpenOffice) or http://www.geo-solutions.it/doc/ImageioExt-SetupGuide.pdf (PDF), sections “GDAL Requirements” and “GDAL Configurations” for further information on enabling ECW and Kakadu support on GDAL. For further helps on this topic, ask questions.
Daniele
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
NITF formats.
(OpenOffice) or
sections "GDAL Requirements" and "GDAL Configurations" for further
Grazie!
Ci puoi dire due parole su come avete affrontato le licensing issues?
Credo sia di interesse anche per altri progetti.
Salutoni.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
