And I think it will be very difficult to share the sample data for replication due to sensitive information + the .ntf file is 450Mb+
Please let me know if you have any ideas, I appreciate your time.
Hi John,
I was talking about the coverage.xml configuration you may find on
GEOSERVER_DATA_DIR\workspaces\YOURWORKSPACE\YOURCOVERAGESTORE\YOURCOVERAGE
Anyway, if you have any chance to share a minimal set of sample data to replicate the issue locally, that would help a lot in investigating it.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Mon, Mar 16, 2015 at 5:55 PM, Kim, John J. (NE) <John.Kim@…6974…> wrote:
Hi Daniele, thank you for the response, I really appreciate your time.
Here’s the full verbose log from the request:
DEBUG [geoserver.filters] – Compressing output for mimetype: text/html;charset=UTF-8
DEBUG [filter.GeoserverSecurityContextPersistenceFilter$1] – SecurityContextHolder now cleared, as request processing completed
TRACE [ows.OWSHandlerMapping] – No handler mapping found for [/NITFtest/wms]
TRACE [ows.OWSHandlerMapping] – Mapping [/NITFtest/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@…6977…] and 1 interceptor
INFO [geoserver.wms] – Request: getServiceInfo
DEBUG [geoserver.ows] – Getting layers and styles from LAYERS and STYLES
DEBUG [geoserver.ows] – establishing raster style for NITFtest:12AUG12W
DEBUG [geoserver.wms] – setting up map
DEBUG [gdal.nitf] – Creating a new NITFformat.
DEBUG [wms.map] – setting up 512x438 image
DEBUG [geotools.coverageio] – Adjusted Requested Envelope = ReferencedEnvelope[0.0 : 35840.0, 0.0 : 30720.0]
Requested raster dimension = java.awt.Rectangle[x=0,y=0,width=3840,height=30720]
DEBUG [geotools.coverageio] – Coverage read: width = 512 height = 439
DEBUG [geotools.rendering] – Drawing coverage Gridcoverage2D[“12AUG12W”, GeneralEnvelope[(-34.5, -34.48861047835991), (35805.5, 30685.511389521642)],
DefaultEngineeringCRS[“Wildcard 2D cartesian plane in metric unit”]]
Image=RenderedOp[“ImageReadMT”]
DEBUG [geotools.rendering] – Transforming coverage envelope with transform PARAM_MT[“Affine”,
PARAMETER[“num_row”, 3],
PARAMETER[“num_col”, 3]]
DEBUG [geotools.rendering] – Using interpolation javax.media.jai.InterpolationNearest@…6978…
DEBUG [geotools.rendering] – Raster Symbolizer
DEBUG [geotools.rendering] – Unable to create a granuleDescriptor org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer@…6975… due to jai scale bug
DEBUG [geotools.rendering] – Computed scale denominator: 249999.999999999
DEBUG [geotools.rendering] – Processing 1 stylers for http://www.opengis.net/gml:GridCoverage
DEBUG [geotools.rendering] – creating rules for scale denominator – 250,000
DEBUG [geotools.rendering] – Expanding rendering area by 1 pixels to consider stroke width
DEBUG [geotools.rendering] – added attribute grid
DEBUG [geotools.rendering] – added attribute params
DEBUG [geotools.rendering] – Querying layer http://www.opengis.net/gml:GridCoverage with bbox: ReferenceEnvelope[-70.0 : 35910.0, -70.13698630136986 : 30790.13698630137]
DEBUG [geotools.data] – Recasting feature type to subtype by using a ReTypeFeatureReader
Requested raster dimension = java.awt.Rectangle[x-0, width=512,height=438]
Corresponding raster source region = java.awt.Rectangle[x-0,y=0,width=35840,height=30720]
DEBUG [geotools.rendering] – Rendering Raster Gridcoverage2D[“12AUG12W”, GeneralEnvelope[(-34.5, -34.48861047835991), (35805.5, 30685.511389521642)],
DEBUG [geotools.rendering] – Raster rendered
DEBUG [geotools.rendering] – Style cache hit ratio: NaN, hits 0, requests 0
INFO [geotools.wms] –
Request: getMap
Width = 512
Height = 438
Tiled = false
Palette = null
FeatureVersion = null
SRS = EPSG:404000
Styles = [StyleImpl[ name=raster]]
Layers = [org.geoserver.wms.MapLayerInfo@…6979…]
MaxFeatures = null
Exceptions = SE_XML
StartIndex = null
Crs = LOCAL_CS[“Wildcard 2D cartesian plane in metric unit”,
LOCAL_DATUM[“Unknown”, 0],
UNIT[“m”, 1.0],
AXIS[“x”, EAST],
AXIS[“y”, NORTH],
AUTHORITY[“EPSG”, “404000”]]
Bbox = ReferencedEnvelope[0.0 : 35840.0, 0.0 : 30720.0]
RemoteOwsType = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId =null
ViewParams = null
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = false
SldBody = null
ValidateSchema = false
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Filter = null
Format = image/jpeg
Filters = null
Time =
Get = true
RequestCharset = UTF-8
BaseUrl = http://localhost:9080/geoserver/
RawKvp = {BBOX=0.0,0.0,35840.0,30720.0, VERSION=1.1.0, FORMAT=image/jpeg, SERVICE=WMS, HEIGHT=438, LAYERS=NITFtest:12AUG12W, REQUEST=GetMap, STYLES=, WIDTH=512,
SRS=EPSG:404000)
Version = 1.1.0
Request = GetMap
DEBUG [geotools.image] – Encoding input image to write out as JPEG.
DEBUG [geotools.image] – Getting a JPEG writer and configuring it.
DEBUG [geotools.image] – Writing out…
DEBUG [geotools.image] – Writing out… Done!
DEBUG [ geoserver.filters] – Not compressing output for mimetype: image/jpeg
DEBUG [org.geoserver] – Thread 47 locking in mode WRITE
DEBUG [org.geoserver] – Thread 47 got the lock in mode WRITE
DEBUG [org.geoserver] – Thread 47 releasing the lock in mode WRITE
DEBUG [org.geoserver.web] – cannot convert url:jar:file:/apps/work/lve/catalina/geoserver/webapps/geoserver/WEB-INF/lib/web-core-2.4.2jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
DEBUG [org.geoserver.web] – cannot convert url:jar:file:/apps/work/lve/catalina/geoserver/webapps/geoserver/WEB-INF/lib/web-core-2.4.2jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
DEBUG [org.geoserver.web] – cannot convert url:jar:file:/apps/work/lve/catalina/geoserver/webapps/geoserver/WEB-INF/lib/web-core-2.4.2jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
DEBUG [org.geoserver.web] – cannot convert url:jar:file:/apps/work/lve/catalina/geoserver/webapps/geoserver/WEB-INF/lib/web-core-2.4.2jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
DEBUG [org.geoserver.web] – cannot convert url:jar:file:/apps/work/lve/catalina/geoserver/webapps/geoserver/WEB-INF/lib/web-core-2.4.2jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
DEBUG [org.geoserver.web] – cannot convert url:jar:file:/apps/work/lve/catalina/geoserver/webapps/geoserver/WEB-INF/lib/web-core-2.4.2jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
Unfortunately I could not get the gdalinfo on the sample file because of some configuration issues in our current environment, I got a bunch of file/path not found errors when I ran it, please let me know
If you really need this info and I’ll grab our sys admins and have them fix it.
And lastly, I apologize for my ignorance but could you explain what you mean by / where I can find the- XML of the configured coverage? Are you talking about the original .ntf file?
Thanks again for the help!
-John J Kim
From: dany.geotools@…84… [mailto:dany.geotools@…84…] On Behalf Of Daniele Romagnoli
Sent: Monday, March 16, 2015 9:57 AM
To: Kim, John J. (NE)
Subject: Re: [Geoserver-users] NITF ESPG:404000 image displaying a black image on preview
Dear John,
could you please raise the logging level to verbose, repeat the request and attach the updated log?
The log you have reported suggests that the computed image has an empty layout. We should check why.
In addition, could you also provide some more info please, such as a gdalinfo output on that sample as well as the XML of the configured coverage?
Please, let us know.
Best Regards,
Daniele
On Fri, Mar 13, 2015 at 10:48 PM, Kim, John J. (NE) <John.Kim@…6974…> wrote:
Hi List, I’ve been looking for answers for days and finally gave into asking it on here, any help will be greatly appreciated.
So I’ve added the GDAL plugin to my Geoserver to allow me to view certain NITF images.
I have everything configured per the instructions and I can preview certain images but when I try to
preview larger images in EPSG:404000 it comes up completely black.
Some general info, things I’ve found and tried:
Geoserver version 2.4.2 on RHEL
Preview works fine with images under certain sizes (~30MB + EPSG:4326), but these problematic images
come in 300MB+ and in EPSG:404000. I think EPSG:404000 might be causing the issue here, I’ve tried increasing the WMS memory setting,
decreasing the opacity level for the current style to no luck…
also I’m seeing this error in the geoserver log which I believe is the key:
If anyone has a workaround or a solution to this issue please let me know!
Thank you and I really appreciate the help,
-John Kim
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
