I'm trying to run an Oracle Spatial (10g R2) datastore on Geoserver 1.3.2.
When I fire up Geoserver i get the error:
No CRS for SRID 8307 (WGS84). I did a search and this points back to
geotools, but the post was from Feb this year. Anyone have similar
issues/solutions?
Thanks
View this message in context: http://www.nabble.com/No-CRS-for-SRID-tf2382107.html#a6638803
SRID 8307: is this something defined in your Oracle Spatial? I dont
see it in geoserver's list.
Alex
issues/solutions?
Thanks
Yes, this an SRID that is standard to Oracle. When you say you don't see it in geoserver's list, where are you looking? In the code, or the interface?
Alex
issues/solutions?
Thanks
The interface:
http://localhost:8080/geoserver/srsHelp.do
Alex
interface?
> Alex
>> 1.3.2.
>> issues/solutions?
>> Thanks
It appears from this page that these are all EPSG, so I think the mapping would be Oracle SRID 8307 = EPSG 4326. I was guessing that there was some sort of internal lookup since the provider seems to be reading the SRID out of Oracle. Just starting with Geoserver though...
The interface:
Alex
interface?
> Alex
>> 1.3.2.
>> issues/solutions?
>> Thanks
I think you are correct--try configuring the data as EPSG:4326 in geoserver.
Alex
> The interface:
> Alex
>> interface?
>> > Alex
>> >> 1.3.2.
>> >> issues/solutions?
>> >> Thanks
It's actually setup that way already, so I just tried the opposite (Set the CRS to 8307) returns the same error.
Alex
> The interface:
> Alex
>> interface?
>> > Alex
>> >> 1.3.2.
>> >> issues/solutions?
>> >> Thanks
This looks to be an already identified problem:
http://jira.codehaus.org/browse/GEOT-826
As a hack, you can try to define 8307 in Geoserver by giving it the
WKT text for 4326, see
http://docs.codehaus.org/display/GEOSDOC/Custom+projection+definition+in+Geoserver
Any other ideas?
Alex
> geoserver.
> Alex
>> > The interface:
>> > Alex
>> don't see
>> >> interface?
>> >> > Alex
>> >> >> 1.3.2.
>> back to
>> >> >> issues/solutions?
>> >> >> Thanks
The suggestion to create an alias to mdsys.cs_srs worked. I can now get WMS layers out of Oracle.
WFS is another story, but we'll leave that for another day.
Thank you Alex.
Any other ideas?
Alex
Thank you Alex.
You are welcome, glad it worked.
Alex
