I tried to install GeoServer 1.6.0 to CentOS according to "CentOS (Red
Hat) 5.1 Install"
http://docs.codehaus.org/display/GEOSDOC/CentOS%20(Red%20Hat)%205.1%20Install
I finished "Install Java" and "Install Apache Tomcat ", and deployed
GeoServer 1.6.0.
However, no map features are displayed in OpenLayers map preview, at
/geoserver/mapPreview.do
On the other hand, in SVG map preview, map features are displayed and
WFS request working well (I can get WFS features using uDig).
What do I have to do to display map features in OpenLayers?
Working environment is below.
CentOS 5 (final)
Apache Tomcat/6.0.16
Java version "1.6.0_04"
Thanks
Nobusuke IWASAKI Ph.D., Researcher
Ecosystem Informatics Division
National Institute for Agro-Environmental Sciences
Tsukuba, Ibaraki 305-8604, JAPAN
Tel / Fax 81-29-838-8226 Email: niwasaki@anonymised.com
View this message in context: http://www.nabble.com/No-map-features-are-displayed-tp15494740p15494740.html
Nobusuke ha scritto:
Hat) 5.1 Install"
GeoServer 1.6.0.
Well, nothing, it should just work. Let's try to isolate the
issue.
First, can you try the following straight GetMap request (adjust
the host name as needed):
http://localhost:8080/geoserver/wms?bbox=-130,24,-66,50&styles=population&Format=image/png&request=GetMap&layers=topp:states&width=550&height=250&srs=EPSG:4326
If this one works, then I bet you have a javascript issue: is
javascript enabled in your browser?
If it does not, can you go into the geoserver data directory,
logs sub-folder, and see if you can find any stack trace
or error message?
> issue.
I try it. Only error massage is returned.
>> <ServiceExceptionReport version="1.1.1">
>> <ServiceException>
>> java.lang.NoClassDefFoundError: Could not initialize class sun.awt.X11GraphicsEnvironment
>> </ServiceException>
>> </ServiceExceptionReport>
And, I find error massage in "geoserver.log"
>> 2008-02-15 19:06:20,855 WARN [geoserver.ows] - java.lang.NoClassDefFoundError: Could not initialize class sun.awt.X11GraphicsEnvironment
>> at java.lang.Class.forName0(Native Method)
>> at java.lang.Class.forName(Class.java:169)
>> at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:68)
>> at java.awt.image.BufferedImage.createGraphics(BufferedImage.java:1135)
>> at org.vfny.geoserver.wms.responses.ImageUtils.prepareTransparency(ImageUtils.java:114)
>> at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:217)
>> at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:432)
>> at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
>> at org.geoserver.ows.Dispatcher.response(Dispatcher.java:602)
>> at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
>> at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
>> at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
>> at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
>> at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
>> at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
>> at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
>> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
>> at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
>> at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
>> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
>> at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
>> at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
>> at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
>> at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
>> at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
>> at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
>> at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
>> at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
>> at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
>> at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
>> at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
>> at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
>> at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
>> at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
>> at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
>> at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
>> at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
>> at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
>> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
>> at java.lang.Thread.run(Thread.java:619)
Nobusuke
Aaah, your PC is headless (no X windows running).
You'll have to add the -Djava.awt.headless=true option to your Tomcat install. I think
export JAVA_OPTS = -Djava.awt.headless=true
in the environment that runs Tomcat should do the trick.
Yeah!
I can get map feature!
I add
export JAVA_OPTS="-Djava.awt.headless=true"
in the .bashrc
Thank you!
Nobusuke
