[Geoserver-users] (no subject)
Hi Andrea
Thank you for your answer!
I previously posted under emailadress oliver.jeker@anonymised.com; did now properly subscribe to geoserver-users@lists.sourceforge.net with emailadress liberogis@anonymised.com
Concerning you questions....
I did provide proper username and password for the sqlserver datastore.
My guess is that they are correct, as I get no errors when accepting the datastore settings in the admin interface (I do get connection errors if I change either username or password)
The server does accept standard sqlserver connections, which connect over TCP/IP.
Do I have to provide username and password again when configuring a featuretype for sqlserver datastore?
Any other suggestions what could be wrong?
Maybe there is something wrong with the catalog of spatial tables in our sqlserver? What query does geoserver use to provide a list of spatial tables?
Oliver
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
