[Geoserver-users] (no subject)
Hello Group!
Is there a solution to getting a collection of GeoTiffs into GeoServer without using REST or the Import Data feature (available only in the Suite)?
Thanks, DFM
http://geobatch.geo-solutions.it/
ยทยทยท
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Wed, Sep 25, 2013 at 2:41 PM, David McKinney <dfmreader@anonymised.com> wrote:
Hello Group!
Thanks, DFM
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ciao David,
adding to Alessio's email.
The standard option is create a quick script using for instance CURL
(it works on both windows and linux) to submit geotiff files to
geoserver.
Some usefule links:
http://sharemymappingknowledge.blogspot.it/2013/01/uploading-coverages-to-geoserver-using.html
http://docs.geoserver.org/latest/en/user/rest/examples/curl.html
http://comments.gmane.org/gmane.comp.gis.geoserver.user/15557
As of GeoBatch,
that is an external tool that can be used to automate certain tasks.
We are preparing a workshop for it that will be given on the 3rd hence
in a couple of days you'll be able to use the workshop to check what
can be done with it. As an instance it is possible to preprocess and
ingest in GeoServer a bunch of GeoTiff files.
Again, you can achieve something similar via scripting with bash or
bat files + curl and rest interface.
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Mon, Sep 30, 2013 at 10:36 AM, Alessio Fabiani
more information.
@alfa7691
Hello Group!
Thanks, DFM
from
from
